my friend can cop me some ecu p28 free. but i wanna give him the right information. does it have to come out of a civic ex 92-95 Si?? or can it be any civic ex 92-95 manual? i saw some mugen chip for 15 bucks on ebay. is that the right chip to get? also i saw on comparing a before ecu and after ecu. i saw that more than 2 chip been installed in the ecu. what is that called the one on the left side of the chip? and i got a laptop insiron 5100 DELL. can i connect it to a chip burner? and where do i get a burner at cuz i search ebay for ecu burner nuthin shows. help? dont tell me to search i dont know what to search for.
ECU p28 from si or a regular ex?
EX/SI ECU both were p28 from the 92-95. Dont buy those so called ebay chips find a good tuner and put a decent chip in there. I made the mistake of purchasing a skunk2 chip off ebay. It runs the car just hella rich when VTEC engages. You can prob get a burner at moates.com or something like that.
http://jdmshit.com/ecu/index.html
that should help i recomend the jdm shit race h22 or mugen just remeber to get that puppy tuned
Originally posted by defjamon22zwhy those chip have rev limit less than 10 rpm? ? i heard a h22a engine could do 12,000rpm.. did i heard wrong??
My Members Ride Thread
Originally posted by deevergoteYou have to think outside the box to get IN the box!
Originally posted by defjamon22zgoddam. are u sure? 2 people swear h22a can do 12 rpm when i tune my ecu change the rev limit to 12000 RPM. damm.. does everybody agree with this guy? i cant do more than 8500 rpm?
ohhh.. well i'm new.. i just thought.. that since it's 200hp at 8rpm stock.. that if i had it rev to 12rpm. it will continue to be 200 hp all the way to 12rpm while gainin more mph. so when i switch gear at 12rpm it will drop down to like 8rpm and that's still 200hp right there.. so basically. stayin on 200hp thru out the whole race even when changing gears. i also once thought that since it's 200hp at 8 rpm.. that when it goes to 12 rpm it might be 250hp stock. i never really look into it i'm new at this rev limit and h22a and ecu tunin so my bad ya'll..thanks for tellin me tho
Originally posted by defjamon22zohhh.. well i'm new.. i just thought.. that since it's 200hp at 8rpm stock.. that if i had it rev to 12rpm. it will continue to be 200 hp all the way to 12rpm while gainin more mph. so when i switch gear at 12rpm it will drop down to like 8rpm and that's still 200hp right there.. so basically. stayin on 200hp thru out the whole race even when changing gears. i also once thought that since it's 200hp at 8 rpm.. that when it goes to 12 rpm it might be 250hp stock. i never really look into it i'm new at this rev limit and h22a and ecu tunin so my bad ya'll..thanks for tellin me tho
where did you come up with this?
AN h22a is not an F1 motor. You wanna spin a rod go ahead. And the normal h22a redline is not 8k unless your running a type s or a euro R if not the F20B. Other than that h22a redline is 7200. Your friends are dumbasses thats all I have to say. ANd you feel no power gain past 7500 if not sooner.
