Originally posted by flight50
h22 type-s
not all h22's have 10:6 compression first of all. those are the jdm (200hp).usdm (190hp) are 10:1. and i agree that .4 in compression isn't much which really defeats the purpose of going to the type s. you can use a thinner head gasket and mill the head and get you close to 11:1. might as well resleeve and go 11:5 or so. oh and the 20whp is adding 2 points to compression. plus perhaps subtracting 2mm from the stock bore to add more gains. i was on the mind set of what i wanna do, my bad. i wasn't speaking of if you go just type s piston, you get type s power. that i do know. its an totally improved head design over the earlier year models. from air flow to components within that made up the type s. as far as tb, depends on if your auto vs manual equipped. its been said that autos have a smaller tb than the manuals and that the fuel/air delivery may me slightly differentLast edited by flight50; 11-06-2006, 02:38 AM.91 Ex CB9
JDM h22 auto swap, now w/H23 5spd conversion, short ram intake w/K&N filter, DC ceramic header, 2.25" custom catback exhaust, AMR Engineering coilovers, 205/50/16's Enkei RS5's, front slotted rotors, Xenon body kit.
W.I.P.
p72 ecu on Hondata
To Come
Weight Reductions
R33 or R34 front end
in an older issue of honda tuning the 11.5.1 mhule pistons gave 10 whp with no tuneLast edited by dan21; 11-15-2006, 04:47 AM.U dont work U dont eat
U dont grind Udont shine
1st car 90 CB7 lx auto coupe
present car 90 CB7 ex clutch coupe
1st motor f22a1 2nd motor f22a4 present motor JDM H22a with m2b4 trans
Originally posted by dan21in an older issue of honda tuning the 11.5.1 mhule pistons gave 10 whp with now tune
Can you use thinner gaskets to raise compression on the F22?
i'm really set on some type s pistons for my h22a4 motor, plus i'm burning oil like no tomorrow so piston rings are my guess.. why not upgrade to the type s pistons for a full point bump in compression. I was also wondering if the stock rods would be fine? And how much a new set of oem rings would run ya for them bad boys
