Me and a friend of mine were at a junk jard and foud a saab with a turbo on it. He says that I could make it work. I want to get some more opinions. If it will work what else should I take off the car other than the turbo itself.
turbo
more than power, you will get more torque...from what I know that turbo is really small, so it will spool fast and give u good low/mid range power.Originally posted by EXCoupHow much power will a t3 add?
it will make the car really fun to drive b/c of the extra torque...enjoy...oh yeah u might want to get either a new clutch or one with higher torque capacity.DEVOTE
FS: Lokuputha's Stuff
a lot of turbo housings have rust on them....not a problem...but if you want it to look really nice...get is ceramic coated...not only looks good but also u'll get less heat under the hood.Originally posted by EXCoupThe turbo also looks like it has some surface rust, is that an easy fix
DEVOTE
Originally posted by lokuputhaa lot of turbo housings have rust on them....not a problem...but if you want it to look really nice...get is ceramic coated...not only looks good but also u'll get less heat under the hood.
hmmm, coatings....
I'm a firm believer in them, and would recomend them to anyone.
For the manifold, turbo and downpipe it should be less than 200.00, and in the grand scheme of things, a good turbo kit will cost atleast 2000.00, so another 200.00 is not going to kill you. L8rTurbo H23a3 build has begun01-01-2019
