how do you use the carb cleaner?
header whine?
Take it to an exhaust shop and have them put it up on a lift for you while the engine is running to check for leaks at the gaskets.
Better hope it's a large exhaust leak when using that method of diagnosis.Originally posted by alb_accordwell the only way to find an exaust leak is to have someone block the exit on the muffler and someone else should check for the leak.
