I started getting a check engine code 4 on my chipped po6 (by mrx) so I went through the whole all data procedure and at the end of testing all wires and replacing the whole dizzy I pulled the ecu and put my stock ecu back and pulled the charge pipe of the intake side and set the fuel pressure back to stock and it started, drove with no codes but my map sensor code when I hit boost my problem is that what do I do to fix my ecu it ran great before but how do I figure out what’s wrong with my ecu I pulled the map off of the chip with the burn1 and I know that’s working so where do I go from here?
check problem thing dealler whats it
You using the stock map?
I was talking abuot the MAP sensor not the map mrx burnt you. Sorry bout that.
yeah i got a 2.5 bar one but have not put it in yetOriginally posted by NAiL05I was talking abuot the MAP sensor not the map mrx burnt you. Sorry bout that.
I crashed my car and totaled it so I stripped everything and went looking for a shell I found a prelude so everything is going in there but right before i wrecked it I took of the charge pipeing and ran the stock ecu no problem no code ran great so either it's the chip or the ecu
so if anyone has a working chipped po6 lmk i got cash in hand
I would post pics of the crash but i stripped it, interior and all in about 4hours and had it towed to the yard same day so i never even got a chance to take pics
