ECU Swap?
    ECU Swap?
    What ECU swap would I need with these modifications I'm adding to my F22A1?
    H23 Intake Manifold
    F22A4 Downpipe/Header
    F22A6 Cam
    ~DirtySouthHonda
    Are you looking for an ecu that will control the IAB's on the H23 and be able to throw the fuel at the A6 Cam. If you are then I would say a PT6 A01 would be plug and play for what you are adding.
    Unless you where looking to goto a chipped ECU. Then I would say get yourself a chipped P06 with IAB support. If you do go the chipped ECU route it will open up your tuning possibilities for future mods. larger cam bigger injectors or boost.
    *Note A chipped ECU will require extra $$$ for tuning. I do not recomend running a chipped ECU un-tuned.
    MR Thread
    GhostAccord 2.4L Blog
    by Chappy, on Flickr
      PT6 thats what i got with my h23 intake.......
        if you aren't doing the H23 swap for awhile and have access to a p12 ecu, that instantly gives you 10hp just by swapping ECUs. The prelude S has the f22a1 with 135 hp with this ECU so that would be an EASY 10hp that would take less than 2 min. to install. The ecu is located underneath the passenger carpet in front.
