as the title says, is the stock fuel rail good for a boosted motor as long as i use an aftermarket fpr??
stock fuel rail good for boost??
OHIO CB7's
My Ride
MOD FUND:
better if I could sell some of my stuff.
Build Thread
vouches: oneoffaccord, dep22build, 1993haccord, hostile, da9b16, brian91accord,93 Accord lx, kc8enbTags: None
Then wouldnt it always be on? Or is there an auxilery wire for turn on? This is why 10th, asked for a diagram, Because not everyone is that familiar with wiring nor the fuel pump. Ive never had to rewire one myself, but I do agree 18-20 gauge is not good for something so importent/draws so much amperage. I would highly recommend you use a walbro in fashion of a 255lph fuel pump, so you wont have to upgrade in the future, and at minumum 450cc injectors, depending on psi of boost etc.
WaC!
i am going to use dsm injectors. i am thinking about using a walbro 255 lph pump also. i thought about using the adjustable fpr for tuning reasons.Originally posted by d112crzyYou don't even NEED an adjustable fuel pressure regulator.
You should worry about your fuel pump and wiring it correctly(stock wiring is shitty) and your fuel injectors being big enough first.OHIO CB7's
My Ride
MOD FUND:
Build Thread
What are you going to use for fuel management? If you're going to use a chipped ecu or a full standalone, you don't need an adjustable fpr.Originally posted by T04ECB7i am going to use dsm injectors. i am thinking about using a walbro 255 lph pump also. i thought about using the adjustable fpr for tuning reasons.
i am using an APEXI S-AFC with a wideband.Originally posted by d112crzyWhat are you going to use for fuel management? If you're going to use a chipped ecu or a full standalone, you don't need an adjustable fpr.OHIO CB7's
My Ride
MOD FUND:
Build Thread
