I've been reading a magazine called Everyday Practical Electronics, and in the september to november 2009 issues their is a 3 part section on how to make your OWN programmable Ignition system. and i also found that they made it so you can add a knock sensor to it, and also a LED/Digital tach for it. i'm super excited about being able to have something that i Can build.
from the article it says it features:
so to say the least i'm super excited about this project. I want to start getting stuff for it but i'm moving to indiana here in two weeks and don't really have time or money to be getting this stuff. but What I want to do is have it so I can run an engine on a stand without having to hack up a civic, accord to get a engine to run. Plus I have a few other ideas. What do you guys think though? I"m not looking for profit, this is fun and a project.
- Advance and retard adjustment over a wide range
- Plug-in LCD hand controller for adjustments
- Hand controller LCD shows values and settings for adjustment
- Suitable for single coil ignition systems with a dizzy
- can be used as a timing interceptor or as a replacement ignition
- ignition timing mapped against RPM and engine load
- interpolated values used for RPM and load values between sites
- Optional single map or dual timing maps
- single map has 15rpm sites x 15 engine load sites
- dual maps each have 11rpm sites x 11 engine load sites
- 1 deg or .5 deg adjustments
- dwell adjustment
- knock sensing indication, with optional ignition retard
- suits 1 to 12 cylinder engines (4 stroke) and 1 to 6 Cylinder 2 stroke engines
- 2 debounce settings
- high-level or level level triggering
- points, reluctor, hall effect, digital signal, or optical triggering
- works with many pressure sensors (MAP sensors)
- min and max RPM adjustments
- Min and Max engine load adjustments
- Diagnostic RPM and load readings
- add-on knock sensing unit (optional)
- requires evenly spaced firing between cylinders. For v-twins, you will need two ignition systems and a seperate trigger for each cylinder
