Ecu
    Ecu
    Post The different ecu our cars have what are the best to chip and how much will u gain with h/i/e
    1992 Accord Cb7:
    yeah i was wondering about this too...i heard you can use a different ecu to gain 10hp in a f series but i forgot which one it way.
      that would be the p12 ecu
      1992 Accord Cb7:
        The only one for the f22a is the p06 from a civic...you cant tune an accord ecu.
          tru
            p06 are from the 96 upcivic?
            1992 Accord Cb7:
              pt3
              - stock 90-93 accord a1/a4 ecu
              pt6
              - stock 90-93 accord a6 ecu
              p12
              - prelude S ECU
              - 10 hp gain on a stock F22
              - useless for a heavily modded F22. because it cannot be chipped/tuned like a civic ECU
              p06
              - 92-95 civic ECU (non-vtec)
              - in stock form cannot run any engine besides the civic engine
              - can be chipped/tuned to run any stock/lightly or heavily modded B/D/F/H series
              - has to be converted to VTEC to run VTEC engines
              p28
              - 92-95 civic ECU (vtec)
              - same as p06 except it doesn't need to be converted to vtec, it is already a vtec ecu
              - after it is chipped/tuned it can run both VTEC and nonVTEC engines
                with an I/H/E you will not gain much but there are a lot of variables.
                example 1.
                short ram intake+generic exhaust (they are 2.25")+generic header(they have 1.75" collectors)
                you will be lucky to gain 10hp after a tune
                example 2.
                cold air intake with an air duct+2.5" exhaust+bisi header
                the gains could be pretty significant
                  i see must have a cam see any real gains
                  1992 Accord Cb7:
                    would a p12 out of a 92 'lude work ok in a 93 cb7 ex?
                    Originally posted by HardInThePaint
                    Girls should most definitely rep the shocker. Embrace the shocker.
                    Be one with the shocker.
                    My ride: http://www.cb7tuner.com/vbb/showthread.php?t=187897
                      I can't remember what engine is in the 93 ex, if it's the F22a6 you're better off sticking with the ecu in there to run the Iab's. If it's the a1 go with the p12 for an extra 10hp.
                      Member's Ride Thread
                      Originally posted by mercyboy
                      I'd rather lose by a mile because I built my own car then win by an inch because someone else built it for me..your car is your story, so don't let someone else write the book!
                        it's the f22a1. i just went and checked right now cause i couldn't remember. so i'm on the prowl now for a p12. thanks for the help!
                          found a p06 for 20 bucks is it worth it? to tune?
                          1992 Accord Cb7:
                            Actually, you can tune the Accord PT6 ECU. It's just not as flexible as the P06 and there are a few things in the PT6 that can't be changed.
                            Yea, a camshaft is going to benefit you the most with a tune, becuase a camshaft is probably one of the most significant power adders when it comes to bolt ons. Yes, a camshaft is a bolt on.
                            When using an aftermarket camshaft, it is pretty much useless without a tune. You wouldn't be utilizing it for it's capabilities without tuning air/fuel throughout the powerband to accomodate it.
                            It'd be worth it because that's usually what the P06 runs for these days. However, unless you plan on upgrading at least to a different camshaft, I wouldn't bother getting another ECU and tuning a stock motor.
                            Grab a bisi level 1 or 2 cam, then tow the car to a dyno tuner and drop $300 on a good tune for that P06 to run your engine with your new camshaft, and other bolt ons.
                            R.I.P. Veronica - JDM F20A swapped 2.0 Si wannabe.
                              i see thanks ill just wait for the h22
                              1992 Accord Cb7:
