need base map for dsm 14b/t25 450 cc f22a1 turbo setup, for crome. i tried the bin directory and i didnt see any file. figured id ask here. thanks
Need Dsm Setup, Base Map
first of all there is a difference between a 14b and a t25. the same basemap may not work for both.
and second, you can make your own basemap in crome. there is a crome beginners guide on here http://www.xenocron.com/techcenter.php
it is very easy to make a basemap yourself. start with a stock f22 map and chose the appropriate injector size, create a map. the car should start and drive fine... if its too lean, you'll know. then drive it slowly to a tuner, don't go into boost
sweet thank you sir. much appreciated. i put 14b/t25 cuz nissan has a t25, just wanted people to know. i have the dsm t25. i got the ecu from astrovannin on here, it has a stock base map and a 450cc map. just wanted to see if someone had a base map for my setup that they have used and know that it works good. but i guess i also need a chip burner befor i even can make a basemap.Hey yo uhhhhhh fry man!!!!
What works good for one persons engine, will be different for another engine.Originally posted by 92Inspire View PostJust wanted to see if someone had a base map for my setup that they have used and know that it works good.
My 5.7 LS1 Holden Ute
