Well seems like my acar is giving me the code zero again. I was at first upset that I couldnt figure out why that once was a problem. I found out that if the water temp sensor on the front of the engine is bad then it will solid like the MEL light as soon as you turn on the car, well i got rid of that and I was able to see that I had a code for a few things on including the o2 sensor. Any way I let the car sit and right now When i turned it on i checked the MEL light for shits and giggles and again I get a code zero. Ive replaced the ecu again with one that works I think I have a short some where can you guys help me out thanks ?
Code Zero
i know you would think the its a simple fix. but no i want to be able to check my ecu for codes. and the mel is only on with the paper clip. so that means its good its just either missing a ground or the temp wire is cut. which it is and ill be resoldering it in. then ill go to the junk yard and find out were the ground is at
