Is a P28 ECU plug and play under the floor panel? Do I have to change the wiring harness or not?
P28 Ecu
P28 Ecu
Your car is faster, I'm the better driver
Greetz Erwin
My last ride
Shakes and Fidget - The Game
Tags: None
Greetz Erwin
My last ride
ANY OBD1 ecu will be plug and play.
Now, will it run your motor right? That all depends on what motor you have, and if you have chipped and tuned it.
just because your friend got tuned with the same exact setup you have, and you use the same map, does not mean it will run the same.
Greetz Erwin
My last ride
deevergote is selling a P28 if your dead set on getting one and if not then he also has a p06, PM him if you a interested, im sure he work with you on a price.
-seanMembers ride 15.927 @ 86.76 (f22a1)
Hit the clutch Hit the gear Hit the gas and i'm GONE>>>
Arcadia Green Crew #10
