so yea i bought a chipped p28 that is supposed to have an h22 basemap on it, but there are no resistors soldered into c51 and c52. i was told they needed to be there is this true?
chipped p28
does the ecu work?
Originally posted by newtuner7dont know, the car its going in isnt running at the moment. i have another cb with an h swap, but its an auto so i cant run the p28 in it.Gary A.K.A. Carter
[sig killed by photobucket]
They smooth out the data the ecu uses. That way, it has more accurate readings.
Some people have complained that their ecu doesn't work right without them. I've tuned with an ecu that didn't have them and did have readings that were slightly off. But nothing major. The car ran flawless besides the false readings a the laptop.
You ever use a plx wideband? They come with pretty much the same capacitors. You install them right before the ecu, on d14. They filter out any electrical noise that could interupt the signal from the wb controller.
