Is this ok?
    Is this ok?
    the clamp i wrapped around the pump so that it doesnt move.
    miss my turbo cb7
    the right way is always the best way...so whatever normally holds it is best...BUT...
    as long as it isn't too tight...I guess it's ok...but don't quote me. I think my 240 had something like that done to it's fuel pump and it worked fine.
    Anyone else?
    ____
      bump anyone else. i need a awnser quick. the pump is going in today
      miss my turbo cb7
        im not sure about the electrical tape, i wonder if the gas will dissolve the adhesive?
        anyway that should be fine. even though the book recommends butt connectors and a ziptie around the body of the pump. as long as it isnt crimping it too tight, its just there to make sure the pump doesnt fall out of the rubber mount at the bottom of the bracket. hose clamp is fine, its not like being metal is going to hurt anything at all, plus its solid.
        when i did mine, i took the little rubber bump thats popped into the back of the bracket and flipped it around, so its sticking out the back. then i used a ziptie placed between the bracket, hose, and bump, so that it was centered on the pump, but couldnt slide up or down, or fall off at all.
        [img]http://www.****.com/pics/92exr/walbro255.jpg[/img]
          Ive seen hose clamps/zip ties used on 500-600whp setups for FP's. I wouldnt even bother with tape.
            Get rid of the tape. The clap is fine.
              The gasoline will definitely eat away at the tape, I'd use a zip-tie, but a metal hose clamp should work fine also.
              My Member's Ride Thread
                thanks guys!
                miss my turbo cb7
