Need Base Map
    Need Base Map
    This is the only thing holding me back. Dose any one have a copy of a base map i can have? I did a search but couldnt find anything really. F22 DSM injectors
    wait.......your on boost and ur gonna try to run on stock injectors?
      oops fixed that.
        14b? 16g? 450cc i assume? any other upgrades? psi u are running?
          i need one for stock injectors at 7lb and a second for dsm 450cc at 10lb
          i have a walbro fuel pump, what pressure do you think i should run or should i just try stock?
            run stock pressure and let ur tuner decide what ur fuel pressure should be at but u are insane for even tryin to run any boost on stock injectors much less 7lbs......and what turbo are u running? That needs to be known to make a base map.
              X2 don't go boosting on stock injectors.
              Also remember a basemap is a basemap, don't go plugging it in then boosting around w/o getting it tuned first.
              Also we need to know what programme the basemap is needed for . . .
              Post up a few more details of your setup please.
              My 5.7 LS1 Holden Ute
                well i'm trying to try something different here. the program i need is crome.
                  What are you trying to try different? Stock injectors will be maxxed out well before 8psi.
                  My 450cc's are already at 85% duty cycle at only 9psi.
                  Have you had a look on pgmfi.org?
                    if blowin your motor on stock injectors is "trying something different"........its been done lol
                      lmfao, you guys have no idea. i ran 7lbs on stock injectors and didnt blow my motor. anyone have a base map or not?
                        You are the one asking for something
                          i dont get it......if youve done it before, what happen to YOUR basemap?
                            If we've got no idea, why don't YOU create your own basemap/final tune like some of us have. And then come back and tell us we have no idea.
                              I dont have a basemap, but I have the map for my 16g and 450cc dsm injectors if you want it. It is with a gm 2 bar map sensor as well.
                              Pm me if interested.
