i thought i might as well make a thread dedicated to my build. so here it is.
engine specs:
Type: F22a4
Engine Mods:
Master Power T04E 60 trim turbo
DRAG top mount turbo manifold
Forged internals
2.5" intercooler piping
PLX wideband
780cc injectors
38mm wastegate
2.5" downpipe
ported/polished/built head
ARP headstuds
Apexi turbo timer
WEB CAM camshaft
AEM cam gear
Walbro 255plh fuel pump
bigger map sensor
Trans Mods:
OBX LSD
LSD clutch
new axles
resurfaced factory flywheel
new HONDA fluid
list wil be updated and changed regularly.
Goals:
mild build on a F22a4
hp: somewhere in the 300+ range
tq: about the same
Boost: 7-10 everyday and 15 max on stock sleeves but forged internals.
All of this is going to be built on a tight budget.
engine specs:
Type: F22a4
Engine Mods:
Forged internals
PLX wideband
780cc injectors
38mm wastegate
2.5" downpipe
ARP headstuds
Apexi turbo timer
WEB CAM camshaft
AEM cam gear
bigger map sensor
Trans Mods:
OBX LSD
LSD clutch
new axles
new HONDA fluid
Goals:
tq: about the same
better if I could sell some of my stuff.
