Boost control Solenoids?
    Does anyone know who sells just the solenoids without a controller?
    Not the strictly ON/OFF type, but the type that can be pulsed?
    My 5.7 LS1 Holden Ute
    We sell them at haltech!
    You need one? i can probably get you a deal on one.
    What are you going to be using to control it?
      Hondata - PWM output on A11
      Lol would you want to ship it as well . . .
      Also how many wire are they?
        2 wire, you pay shipping, of course. Ill check out a price for you on Monday when i get back to work. We ship a lot of stuff internationally, and knowing that youre a fellow boosted cb7tuner, of course id ship for you good sir. Even if it is for a hondata I suppose...
        har har
          Haha I know . . . I got the rundown from Jose AFTER I'd brought it.
          That would be great if you could do that - Its hard finding people willing to ship this far out. I can make it easy for you, it can be shipped straight to Honda NZ
          Just looked on their site, and I see its a 3 port - whats the 3rd port for?
          Do you hook the connections up the same as a MBC?
          Edit: While I'm at it you wouldn't be able to do a 3bar map sensor as well could you? And are you able to provide values for it?
            We have 2 and 3 bar map sensors, I can get you pricing Monday. Also, the three ports are used for different reasons. The main reason is for running high boost or max boost with an external wastegate. If you pressurize the top of your external wastegate, it makes it open up even later than when it is not pressurized. Thus, you run one line into it, and then one line to the top and the bottom of your external wastegate.
            What values are you needing btw?
              What are you using to tune??? GM 3 BAR sensor values are integrated in CROME. The solenoid has three ports one in from vac/boost reference.... 1 to wastegate (the top of the wastegate- bottom port on the WG still goes to straight reference, or you can T it off before the solenoid....), and 1 that when the solenoid is oscillating to bleed off through... On the AVCR solenoid... You leave the bottom port (on the solenoid) open.... to breathe/bleed off...
              make sense???
              SOme are different though... I know the one with the EE boost controllers are... wish I could be more help. I bought the AVCR and its fucking awesome..
              750 WHP/575 TQ CD5 Raping a street near you....
              realHomeMadeTurbo.com / Kaizenspeed.com / LSD Motorsports / Tempest Racing /SpeedFactory /ExplicitSpeedPerformance
              GFI HOLLA!!!!!!
              http://www.youtube.com/watch?v=Cdiz0k0Rudw
                make sense???
                wow im lost. can someone remind me why im boosting??
                  ARGH...my brainnn....knowledge...my only weakness...that and bullets <_<;
                  Confucius say...when god gives you gators...make Gatorade
                    That makes sense - Thats how I have my MBC connected atm.
                    What make are the map sensors Haltech lists?
                    I will need these values for the map sensor (3bar one) To allow a custom map sensor to be made in Hondata.
                    Scalar - mbar/volt
                    Offset - mbar
                    Thanks
                      Scalar - mbar/volt
                      Offset - mbar
                      Thanks
                      They are gm style 3 bar map sensors.
                      I sent you a pm good sir.
                        I have a GM boost solenoid on my accord. Works great and was around $20 i believe. And yes it is pulse width... You will need to order pigtail with it... If i remember correctly it came from the factory on the Cyclone and Typhoons...
                        12.5 at 114.6mph 15psi
                        11.7 and 11.5 20.5psi
                        F22a1
                        60-1 td06h turbo
                        Darton mid sleeves
                        85.5 wiseco 8.8:1 forged pistons
                        Crower pro billet rods
                        Custom ported head.
                        KMS valves
                        F23 headgasket
                        ARP H23 headstuds
                        H23 upper intake manifold
                        F22a6 lower intake manifold
                        Intake manifold is gutted
                        AEM EMS 1040u
                        FIC 850cc injectors
                        Walbro 255 pump
                        H23 manual trans
                        Prelude shifter assembly
                        Forbidden short throw
                        Nitrous Express Kit installed, never used on this motor
                          I would have gone down the track of factory plugs, but simply put, the Cyclone and Typhoon don't exist over here.
