Part # 12223861
I recently ordered one direct from GM, I am wondering if anyone has a diagram or can explain to me how to hook this thing up(can it simply replace the stock map sensor?) and where to liberate the harness plug for it. Also what all do I have to do to Uberdata to make it work ie maps etc. I want to tune for 20lbs but run a max of say 15-18 on the track, DD at 10lbs.
My engine is built and am using chipped p06 with uberdata, so anyone with help would be apreciated. Thanks!
Here are the connections:
MAP Function MDP
A Ground Black
B Signal Light Green-Black stripe
C +5 Volts Green-Yellow stripe
MAP Function MDP
A Ground Black
