supercharged H22 cb7. Any out there?
    I really want to go supercharged but can't find any info on it. I read countless post from other forums but nothing has given me any signs that it'll work. So far the only kit that I know of is Jackson racing. They only have a kit for obdII which my h22a is but I converted to obd I. The other thing is the mount kit for the supercharge, will it clear my hood on the cb7? What is really the difference between the obd I and obd II motors. All the intake manifolds are the same. They even use the same part numbers. Yet jackson racing don't make a kit for the 96 and older h's.
    So why don't jackson make a kit for the 96 and older h22's? This crap puzzles me.
    I've been down the turbo road already so I want to try something new. If my last option is turbo then I will have to go turbo.
    because it doesn't fit in the other generations...(not meant to fit). Only meant to fit 97-01 ludes
    Yeah, Preludes
    Why can't people just search OT to see if someone else posted the same random thread?
      are you talking frame wise or motor.
        My brother and I have talked about this quite a bit, he said he was reading that an Eaton M90 supercharger will work, if you can find the intake manifold for it. He said that the M90 supercharger comes on the supercharged Thunderbirds. It'd definitely be something to look more into. I think a supercharged cb would be sweet, and different
          Look in youtube.com
          Dude has a h22 supercharged, dope!
            I think i am going to try it personally. Not too many supercharged 4 bangers around....
            well time to go to work.
              So i just read a little and i like the twin screw supercharger right now for the low end. That way in an H you get great power all around.
              Now what should i do about the bottom end? I would want to go all out on the top end and get everything. But i'm not sure about the bottom end.
              Would it handle the extra pressure without any serious modification at the higher compression? Or should i look into a rebuild? I would rather be able to go stock for now or at least with a similar compression so if i ever take it off ill still have a strong running H22.
              What are some ideas?
                I think it would have to be frame wise because there is no major difference at all from the ODBI and II. But you could always just customize it. Look at a lot of turbo CB's.... mostly DSM kits from what i hear.
                It can be made to happen.
                  it has to do with the positioning of the brake master cylinder for the belt.
                  one of our members has done this with the h23a vtec.
                  http://www.youtube.com/watch?v=F9Joo...eature=related
                  member: http://www.cb7tuner.com/vbb/member.php?u=5682
                    I plan to run about 7 lbs on my stock block. But building a stronger block is probably the right way to do it if you had the money. Honda has awe some heads already so why people redo their heads is a ? to me. All you really need is the rods and lower pistons unless you want to make high boost. Then you'll want new sleeves. Over bore sleeves even better.
                    I watched some vids on youtube but none can really answer what I'm looking for. Been reading on so many different forums and every one giving the same answer.
                      Hearing the whine of that charger on that Youtube video, wow. I love it. Makes me wanna go drive fast, or something... but I don't have that whine, I fail!!
                        If I get the correct help, which I think I'm going to get from quickaccord93, I may attempt this supercharger thing instead of going turbo.
