Ok, so I'm looking for the flow rate and pressure rate for the MHI EvoIII 16G turbo. I installed the 16G/14B onto my car it my ring lands blew. Oil was also coming out of my turbo into my charge pipes and intake. The forced performance filter / restrictor didn't do balls as far as reducing the pressure, I installed a industrial flow control on the turbo oil line and a pressure gauge as well. At idle my gauge to the turbo read 80 psi.
I know that's way too high. I reduced the pressure by limiting the flow of oil. The problem I'm running into is that with the pressure restricted at idle to 20 psi, when I reved up the motor the psi would still jump up to about 70-80 and I only reved it to about 4-5K.
I'm worried about blowing the next turbocharger. I WON'T DO IT, I know people just use a little ball valve to restrict the flow, but what about the pressure?
What pressure are the MHI 16G (EVOIII) rated for?
What's the flow rate for these turbos?
Should I use a pressure regulator instead of a flow control?
