I am wondering what the stock sleeves can handle HP wise. Some people tell me 400HP some say 500HP? Does anyone know for sure??
How much can stock sleeves handle?
On what engine...
There are way to many variables to answer your question outright.
The cylinder walls can handle lots of hp if you have the rest of the engine and setup extremely efficient. I am assuming you are talking about boost. So you most likely want to know how much boost you can run without blowing up the motor, whatever that motor might be, and whatever setup it is running.
We need a lot more information before someone can give you an answer.
That being honda motors have held 500 hp without after market sleeves, in fact there are a few s2000 motors holding 600+ hp on completely stock internals.
I am not a boost guy, so one of them will have a better idea on how to answer you question once you provide more information.
you mean distorting?Originally posted by bcjammerx View Postthey may not crack...how about bowing though
its an f22 block, h beam rods from bisi. cp 9:1 pistons, port n polish head, h23 IM port and polished, kms springs and retainers, 3 angle valve job, valve guides and seals, bigger TB holset hx35 turbo, not sure how many lbs im going to push. Pretty sure i am going w/ Hondata tune.Originally posted by Ghetto_CB7 View PostAgain that all depends on your setup. You haven't even told us what motor your using.
Things like compression ratio, rods, boost, and probably most importantly the tune have far more to do with how much hp your motor can take then weather it is sleeved or not.
360whp here on stock sleeves, about 10,000kms so far. Going for 400whp next year, daily driven.1991 Accord LX Coupe - Boosted F22 - 5spd LSD - Shaved Bay - Work VSXX - Recaro SRD
Member's Ride Page | Video of my CB7, Open Downpipe peelout
__
