what ratio??
    what ratio??
    what ratio on pistons should i run if i plan to build my bottom end. Im going to sleeve it, pistions, and rods. Im also going to p&p my head. Im going to use the DSM turbo stuff for my set-up. Any info on this would elp me alot. thanks
    if ur boosting i'd only go as low as 8.5:1 but our stock 8.8:1 is fine also. Depends alot on if u want to keep the low end tq that u have. The lower the comp ratio the lower your tq will be b4 the turbo kicks in
      thanks alot guys. i'll let you know more as my project begins.
