What all would be involved in detail on replacing the stock map sensor ans what type out of what vehicle would i use, want to go from the factory 1 to a 3 bar, guessing just take the box apart and clip the wiresm but which one would i use, throw some ideas at me for people whos done this. how to and what vehicle to get it from on ebay... thank...
replacing factory map sensor
Originally posted by tootall View Postusing crome pro for datalogging and innovate lc-1 wideband boosting 11, wanting to go to 15 psi
You need to select which MAP sensor you are using under your tuning program because different MAP sensors all communicate a little differently.
As for installation there are plenty of threads all over regarding wiring. Essentially you will need the GM style weatherpack connector that plugs into the GM map sensor. You will clip away your factory MAP sensor connector (located in that black box in your engine bay), and wire in the new connector accordingly. Its a fairly simple process.
You should be able to aquire a GM 3 bar online pretty easily from many places. It may be sold as a vehicle specific, or also several tuning sites sell the GM 3 bar alone, as an individual product, for use in other vehicle applications like you will be doing.
The GM 3 bar map sensor can read up to 28 pounds of boost.Last edited by ON_N20; 09-30-2012, 12:49 PM.ON_N20Nitrous = Been there. Turbo = Now. Nitrous + Turbo?... LOADING
Ive already had my factory map sensor out many times and familiar with it and know there are the 3 wires coming off of it going to the plug but does anyone have a thread on here just showing how to install in detail, what color wire to which and so on, do they usually mount or is there room for them in the black box, just would like to see pics or a good thread on the subject, and thanks for your help bud appreciate it, and is the gm 3 bar the best one to go with? thanks. would rather have a 2 bar because of voltage issues dropping maybe but guess a 3 bar will be fine. cant find a thread on here...
Originally posted by tootall View PostIve already had my factory map sensor out many times and familiar with it and know there are the 3 wires coming off of it going to the plug but does anyone have a thread on here just showing how to install in detail, what color wire to which and so on, do they usually mount or is there room for them in the black box, just would like to see pics or a good thread on the subject, and thanks for your help bud appreciate it, and is the gm 3 bar the best one to go with? thanks. would rather have a 2 bar because of voltage issues dropping maybe but guess a 3 bar will be fine. cant find a thread on here...
Signal / Honda / GM
+5V - Yellow/Red - C
Ground - Green - A
Signal - White - B
you have to rescale your Bin file for the 3bar as the scaling is completely different vs the stock map sensor. if you simply install the 3bar and do not make any modifications to your bin file, the car will turn on and immediately shut off.
luckily for you, the rescaling is easy if you do select the gm 3bar as john cui(creator of crome) already has the gm 3bar sensor available for selection in the map sensor section.
furthermore, once you change to 3bar you will have to retune the vehicle. the columns become shifted (example, what once was 3psi might now be 4.8psi (column shift) so the car can run leaner/richer in certain areas. including out of boost.
.02Last edited by WiKKeDV16; 10-08-2012, 09:02 PM.
Praise The Lowered...
Correct^
the only way for a vehicle to run properly with a piggy back is to run the stock map sensor, but my question is... why would you run a piggy back when there are so many more options,???
considering the advancement in tuning technology... the cost of a piggyback is roughly the same as getting your ecu chipped and basemapped for your vehicle to run properly until your ready to get the car tuned..
Thanks for the info btw
