Hey guys, my turbo doesn't boost anymore. We installed it 2 days ago and it was working fine until I messed with the BOV and charge pipes. I installed the BOV myself, right after the pipe that goes to the TB and then I changed 1 charge pipe to a metal one because the old one was rubber and kinked. Now, I got no boost, whats going on?
Not Boosting... ????
Originally posted by Alex EXHey guys, my turbo doesn't boost anymore. We installed it 2 days ago and it was working fine until I messed with the BOV and charge pipes. I installed the BOV myself, right after the pipe that goes to the TB and then I changed 1 charge pipe to a metal one because the old one was rubber and kinked. Now, I got no boost, whats going on?
Boost leak! lol. just check your charge pipes again. all of them and wherever theres a connection. when changing those pipes ya migth have wiggled it to much and caused one of the charge pips to come apart. hope this helps!
i had adam (h23accord) reroute the bov to the back of the intake mani. They said they heard it blow off. I'm pretty sure its just the w/g actuator is stuck and keeping the flapper open. Slow spool, exhaust is kinda loud, and doesn't really boost till high rpms..all signs point to the w/g flapperKnowledge is power...in EVERY sense of the word
AH! i just figured out a great way to get around the a/c line easier without hacking up the mani as much. Not sure why it JUST came to me but whatever. The flange on the o2 housing that mates to the turbo...remember how thick it was? Even tho its cast iron it can still be shaved down to half its width. Shaving it down won't make it weak unless you shave it down to about 25% of the original width. That would make for almost 5-7mm of difference which would be more than enough to get the 02 past the a/c line!!! Discuss..Knowledge is power...in EVERY sense of the word
wow antoine thanks alot!!Originally posted by midnite racer xAH! i just figured out a great way to get around the a/c line easier without hacking up the mani as much. Not sure why it JUST came to me but whatever. The flange on the o2 housing that mates to the turbo...remember how thick it was? Even tho its cast iron it can still be shaved down to half its width. Shaving it down won't make it weak unless you shave it down to about 25% of the original width. That would make for almost 5-7mm of difference which would be more than enough to get the 02 past the a/c line!!! Discuss..
lol
You have been defeated by a car with child locks, how embarassing...
"I noticed my f22 felt "healthier" until it blew up." <Myk>
i can maybe shave off the manifold where that missing stud is and put it back in and torque it... i took it to a mechanic shop today to see what their quote would be to do all of thatYou have been defeated by a car with child locks, how embarassing...
adam's boosted??Originally posted by midnite racer xi had adam (h23accord) reroute the bov to the back of the intake mani. They said they heard it blow off. I'm pretty sure its just the w/g actuator is stuck and keeping the flapper open. Slow spool, exhaust is kinda loud, and doesn't really boost till high rpms..all signs point to the w/g flapperShift_BOOST
BOOM!
