a h22 hatch is a beast, put the seats back in and cram it full of kids. leave the accord be. but if u r going to sell switch the motors then boost the h22. you could always get another f22b for cheap, h22's are a little more pricey.
boost or vtec?
A turbo set-up isin't the only thing that will boost it...Originally posted by LXaccord92i dont know, but i always hear dont boost stock h22`s, but that could just be what is heard and not true, but if it is indeed true, dont swap and turbo cause then u need to build the motor and such, i would just run a compression check on ur motor, stay up on the maintenance, run a chipped ECU for turbo (duh!) and tune it for 9.5-10psi and only run like8 that way it is rich, do it.. way better than going through the headacke of building a block for boost when it is only a day to day commuter....
Automotive Service and Fabrication In SOCAL!! https://www.facebook.com/JLRFAB
i say go boost and yes it is a cheap way to gain hardcore power and is not looked down apon i say swap then boost =) id do that if i had a h22 layin around cause i am already buildn my turbo kit =) more then half way there
~Nick~
