i have a front mount and a side mount intercooler. Can i run both of these at the same time and if so is it good or bad.
Intercooler question
intercooler question
Originally posted by h22sparklejust run a front mount a side mount is garbage. and no dont. I f you do you the hell with you and your setup
Originally posted by rickyduckworththen just one IC will probably cost you 2 or 3 lbs of boost......
and sidemounts suck and are really not used for performance, more like "it's better than nothing and i have no other options"
The side mount should be fine for that turbo... I dont know how this would compare to say a Supra but the stock supra side mount is superior to say an hks FMIC. Stock turbo usually dont need the bigger one and I'm guessing the one off the 4g is the same.Oil leak?What oil leak? That's just sweat from all that horsepower!
Applied knowledge is power!
NITROUS FOR YOUR BODY
BIRTHDAYS ARE JUST AROUND THE CORNER
registration is free
FMIC is te way to beh23a3 cb7 turbo sold
FS: 1 Piece JDM Headlghts blackhoused
My Members Ride !
New ride
'07 GTI Mk5 6spd
this is seriously one of those ideas that you need to do a lot of research on. It was one of the first ideas i had when looking into the intercooler thing. Ran across some sites and found out that one FMIC is better at cooling and doesn't cause a pressure drop that FMIC+SMIC would. You can't cool ambient air down more than its already cooled if its down to ambient. In closing...search more not necessarily here but something like howstuffworks.com would be great to start fromKnowledge is power...in EVERY sense of the word
