I have an F22A1 with stock internals, using a 1G DSM Manifold, 1G DSM 14B Turbo, DSM 450cc injectors, and a chipped ECU w/ Uberdata. Now I have the ECU setup a little rich at full boost (right now only 9-10psi) if I'm not mistaken I think it's actually running like 10 something on the wideband. Anyways, I want to up the boost just a LITTLE bit by just getting something as simple as a manual boost controller. Does anybody have any suggestions of what the max psi I will be able to run with my setup. I really only want to increase it to maybe 12 or 13psi. I'm sure it will handle it just fine, but I want a second opinion on this right now cause the way it sits now, it runs just fine, very reliable, and there isn't anything wrong with it at the moment. If I do go off increasing the boost, who knows what will happen.
Whats up willie??? its about time you posted in here!!
