I am using the 450cc injectors from tuner toys(not sure if anyone else on here is using them) and i wasn't sure which seal to use. The stock injectors had the small rubber seals and the plastic rings. The new injectors came with a large rubber seal which didn't look like it would work with the plastic ring. I ended up taking off the stock rubber seals and plastic rings and just using the large rubber seals. Well when I started the car gas went spraying out from the seals. So I replaced the large rubber seals with the stock rubber seals and plastic rings, but I am still getting gas leaking out. Any ideas on which seals to use or how to fix the problem?
injector problem
i got it fixed. the bottom seal was leaking because it wasn't seated properly. i used the stock bottom seals. come to find out i had another leak too. the top o-ring that goes intot the fuel rail ripped a little when i installed it. replaced that o-ring with one off the stock injectors and problem solved.
