Wideband Installed !
    So last friday me and my friend took the time to install my new Zietronix wideband to get the car ready for master tunner. anyways those of you who saw my a/f's from dyno know they hit 13 at one point but after i got a fresh f22a in there the car drives a little different...still fast. i havent logged with wideband yet cuz my laptop has no small serial port thus i gotta go get an adapter but the wideband LCD is showing that my A/Fs are at 9.8 idle lol and between 10.2 and 11 on wide open throttle rapin. This is very weird because at teh dyno the sniffer "said" i was at 12. Two things arise:
    1. sniffer lied lol
    2. the engine swap had something to do with it....
    although ecu stayed the same, injectors stayed the same, sparkplugs and setup stayed the same.
    h23a3 cb7 turbo sold
    FS: 1 Piece JDM Headlghts blackhoused
    My Members Ride !
    New ride
    '07 GTI Mk5 6spd
    pics pls.
      shit i have a zeitronix, but i couldnt figure what wires to hook the rpm signal and shit like that up to, PLEASE TELL ME WHERE YOU CONNECTED THE WIRES FROM YOUR HARNESS!
      My baby laying down some power...
      http://www.youtube.com/watch?v=kd_Q8HSIyqA
        highC, just use the same wiring as a SAFC for the rpm etc. the pin layout is available on Apex-i's website
        nice to hear you got her in
        Formerly 91AccordExR33
        11.68 @ 127mph
        417whp/375wtq
        Sold: 8/2016
          gracias
            searched for my s-afc install
            Red - Power Pin A25 Yellow w/ black stripe
            Blue - Engine RPM Pin A21 Yellow w/ green stripe
            Black - Ground Pin A26 Black w/ red stripe
            Gray - Throttle signal Pin D11 Red w/ black stripe
              seeing as i have a vafc already installed, could the fact that i am trying to connect another rpm signal wire to it be confusing the fuck outta the computer? When i plug the WB rpm signal wire into the a21 the engine will sputter and die...
              SORRY TO BE A THREAD WHORE!
                ^ precisely what i went by when i did my install ! anyone have any ideas about my rich situation.
                My Members Ride !
                New ride
                '07 GTI Mk5 6spd
                  yea...lean it out
                    Do it safely but make sure you keep a safe ratio so that you odnt run too lean for anything. I rather be a tad rich instead of a tad too lean.
                      yea...lean it out
                      i figured YOU would say that . well first of all i wanna log the a/f's vs the rpms and see the whole pciture together. i am not at all familiar with changing things with uberdata nor do i have the chipburner at this point. So I still want you to come up here and tune my car and teach me how to tune so i can do it up here for which you will be paid. The work that wasnt done by me was done by a shop here and the owner of the shop has been contemplating on opening up a perofmance store within his shop, he offered me to manage it. As of yesterday we are in process of becoming the only authorized APR full dealer in Philly and Jersey to chip/flash VW/Audi. So what I will do is have him pay for you to come up here and to train me and another manager in Uber/ Honda flashing and streettuning.
                      My Members Ride !
                      New ride
                      '07 GTI Mk5 6spd
                        hmmm...i'm a consultant now? lol If your going to go to that extent then PM me cause we need to talk about some more stuff.
                          Zeitronix wired to a p13
                          A6 or/wht HO2S heater coil = PURPLE ZT WIRE
                          A21 yel/grn1 ICM RPM SIGNAL = GREEN ZT WIRE
                          A22 yel/grn2 Shorted to A21
                          A23 blk1 GND = BLACK ZT WIRE POWER GROUND
                          A24 blk2 GND = BROWN ZT SENSOR GROUND
                          A25 yel/blk PGM-FI Main Relay (power) = RED ZT WIRE
                          A26 blk/red VTEC Pressure Switch (GND) (VAFC grounded here so not ZT)
                          D11 red/blk TP Sensor = GREY ZT WIRE
                          D14 wht HO2S Sense = PURPLE ZT WIRE
                          prodigymb - make sure your not reading that idle a/f until after the car is fully warmed up. Otherwise the computer's adding fuel. Also, are you using the stock o2 bung?
