hey guys so we turbo'd the car this week and its great except this one problem it surges at idle so we have replaced the dizzy and the plug wires and that helped a little then we replaced the o2 sensor which helped alot but its surging again. last night when you would step on the brake it would quit surging at idle what is that? we checked the brake booster to see if it was working good and it seems to be. So anyone have any ideas as to what else could be causing my surging?
Surging ?????
by surging i mean the rpms go up and the rpms go down like from 550 to 750 the air fuel goes back and fourth too usually around 14 to 18 ughh. sounds like a nasty cam'd engine but i want it to go away. yeah its got a bov. the surging actually went away after we got the new o2 sensor then we drove it around for a hour or so and then stopped again and it started surging again.
somebody let me know in uberdata what do you have your iacv adjust set to? mine is on 25 does that seem right?
also it seems that when you have a load on the car it quits surging like the lights on and it will even out? what is the ELD electronic load detector and what does it do? i think its either that or the iacv.Last edited by midnightrayne; 02-26-2006, 11:31 PM.
The ELD is just a load detector. Its not problem. I'm not even sure if the IACV in uber works. Set it to 0 and see if theres any difference. I still think theres a vac leakOriginally posted by midnightraynesomebody let me know in uberdata what do you have your iacv adjust set to? mine is on 25 does that seem right?
also it seems that when you have a load on the car it quits surging like the lights on and it will even out? what is the ELD electronic load detector and what does it do? i think its either that or the iacv.Knowledge is power...in EVERY sense of the word
