So I’ve been lurking in the member rides page for a while now but none of them seems to mention what size oil fee lines and the need to upgrade an oil pump. I was just wondering what size of hose and AN fittings to use as I’ve talked to some ppl and they’re like bigger isn’t always better. On a side note would it be possible to keep power steering? I know the AC definitely got to go.
The original plan was to do a cheapo eBay build that was going to push 200-220 whp but they had forged pistons for sale so I was like hey why not go big amirite
now the goal is to push closer to 280-300 to the wheel
Currently, I’ve purchased some stuff for the build such as:
-Wiseco Pistons (standard 85mm,9:1), Eagle rods, arp studs
-the fuel system( DSM blues, Walbro 255)
-p06 w/Hondata
-Turbo manifold(Linked below)
https://www.ebay.com/itm/35293744820...4AAOSwvGZh4mlu
-all the gauges and wideband A/F ratio sensor
-Turbosmart manual boost controller
-AEM fuel rail + FPR
The "still need to get list":
just waiting on buying the turbo (thinking GT3076, linked below) and all the tubing and intercooler(2.5 inches)
http://www.performance-world.com/Tur...95855063bb.htm
-92 civic half rad from misimoto
-Turbosmart 38mm Ultragate wastegate and one of their bov
-Cometic Headgasket ( they only offer in 86mm bore, will that be a problem??)
-All misc bearings and seals (Kings bearings)
-Gates Timing Belt
-Water pump (Aisin or something similar)
-ACT Clutch
Also thinking about getting the valves done too with SuperTech Valve and springs cuz mine be old and sticky.
please let me know if I’m missing anything, as this is going to be my first ever major project on this car and this is about as far as I got from lurking on the member rides notably Grumpys, Raf, and Aleks during work at a parts store
Again, thank you all very much for any help
-p06 w/Hondata
-Gates Timing Belt
-ACT Clutch
