Im really having second thoughts on turboing my car. I have 187,000 miles on a stock F22. do you think it will hold up past 200K on 6PSI? The bad thing about this is, I have already bought my manifold, turbo, wastegate, and intercooler.
2ND thoughts.....
2ND thoughts.....
The sig name is new from a local forum. sorry to confuse anyone.
My Member's Ride Page
The Accords gone
but I will forever belong to CB7Tuner
Tags: None
Do a compression test.
That should let you know how good your motor is, right now.
Turbo`ing that bad boy on weak compression or off numbers is not a good sign.
Either way, you could turbo your current motor. It blows up? buy a replacement F22B DOHC. Turbo that. That blows up? get another F22B!
They are relatively inexpensive motors...
1990 Accord Lx F22a1(Daily)
SOLD - will be missed
If everything is maintained well boosting the motor should be fine. Get a compression check as mentioned that will tell you more than enough info.
I dont think the rings will holdh23a3 cb7 turbo sold
FS: 1 Piece JDM Headlghts blackhoused
My Members Ride !
New ride
'07 GTI Mk5 6spd
Thank you all, I am seeing that most of you think that it will be ok, but to be on the safe side ill take your advise and hopefully do a compression check this weekend "my brother has the compression checker" I was going to do one like a couple weeks ago, but my spark plug wire on cylinder 4 is messed up. You can pull off the boot, but it just slides up the wire and, the wire stays connected. Do you think I should just pull the wire? Im only asking because I dont really feel like buying new plug wires when I have like no money.
The Accords gone
