Note-For readers, My car has the F20A3 2.0L carbed engine. I've made it suck through turbo using a TD04 with a 1.75" SU carb
Well I got the last of the flanges today, so put the last peices on finally. Started the car and spent 3 hours just trying to get it to idle properly and under 2000rpm. So I finally get it down to 1200rpm I can live with that for now. So then I take it for a drive, drive off 1st gear not boosting, then 2nd gear and I give it 3/4 throttle, bit of hesitation then 5-6psi, yay it works, then ping ping . . ping. take it back home, retard the timing some more, and take it for another drive, hit 2nd gear 8psi boost . . . . mmmm no performance gain what so ever, bit of black somke coming out the back. Try it again in 3rd gear full throttle at about 3000rpms, bit of hesitation then it goes . . . but no more power than normal??? drive round a bit more . . . then the detonation comes back only lightly, look behind me when on boost . . . blue smoke out the back
check the sparkplugs and sure enough covered in oil. I think whats happened Is because its suck through carb, the massive vaccum in front of the turbo has destroyed the seals in the turbo. Only 15 mins of driving And I've managed to kill it already, unless anyone has any other ideas??
But what I cant work out is why I'm not getting any more power when on boost?
check the sparkplugs and sure enough covered in oil. I think whats happened Is because its suck through carb, the massive vaccum in front of the turbo has destroyed the seals in the turbo. Only 15 mins of driving And I've managed to kill it already, unless anyone has any other ideas??But what I cant work out is why I'm not getting any more power when on boost?
There will be one eventually...
