anyone had any luck with this combination? when i click the 3bar option in uberdata and upload the map, it sets the cel (code 74, wtf is that?) and throws the ecu into some kind on default mode, where no matter how much i change the values in the rom, it runs super super rich... i know the 3 bar is wired correctly, and the rom im using runs 100% with the oem map sensor. the guy at the dyno where we tuned my car couldnt figure it out eather, and hes done a bunch on 3bar honda tunes.... any ideas?
3bar map, and p06..
Originally posted by LoDollar92LXanyone had any luck with this combination? when i click the 3bar option in uberdata and upload the map, it sets the cel (code 74, wtf is that?) and throws the ecu into some kind on default mode, where no matter how much i change the values in the rom, it runs super super rich... i know the 3 bar is wired correctly, and the rom im using runs 100% with the oem map sensor. the guy at the dyno where we tuned my car couldnt figure it out eather, and hes done a bunch on 3bar honda tunes.... any ideas?
its deff in the programming, not the hardware. with the 3bar plugged in, the car will run, just not real well(stock map sensor rom). when that option is checked tho, thats when it fucks everything up. mabey the p06 doesnt like the 3bar option in uber or crome, ive tryed both, same results....i do like having realtime editing tho, cause when it messes it up, i upload the good map again and its all good, heh
Your best bet is to contact him maybe you need to set a few options differently. I mean if its set for the stock map and its already programmed in there and you put the option of the 3-bar on and they both start acting crazy. Maybe the 3 bar is messin with the stock map and then relazys the shit to the ecu and causes the shit to go haywire. Just leave it until MRx can find the program or reformat the program and compare.
Here's my guess, I did a bit of Googling this morning...
74- Cylinder 4 Misfire or a Random Misfire
a condition is present that is creating a cylinder misfire
I think this is an OBD2 ecu code though.....('96 and on ) Not sure, I'm not turboed but firgured maybe this woule help.1992 Accord LX - SOLD
i've never had the chance to figure it out because nobody's ever gotten back to me on it. Which version of uber are u using? Also have you tried selecting things like the 2.5 bar map sensor? And are your vacuum values correct and consistant on the table after you click those options? I had to completely rework acclipseh23's map when i switched it to the 3 bar because the vac values went bonkers.Knowledge is power...in EVERY sense of the word
Originally posted by MRXi've never had the chance to figure it out because nobody's ever gotten back to me on it. Which version of uber are u using? Also have you tried selecting things like the 2.5 bar map sensor? And are your vacuum values correct and consistant on the table after you click those options? I had to completely rework acclipseh23's map when i switched it to the 3 bar because the vac values went bonkers.
ive tryed uber 1.6, 1.7, and crome. no noticeable changes on the map when the option is clicked, and it does not matter how much you change the values, it runs exactly the same. i never thought to try the 2.5 bar option. ill try that, and see what happens. i wasnt sure if there was some compatability issue with the p06 and this option in uber, since most ppl that run a 3 bar that i have talked to have a p28....also, my datalogging port wont work eather, im using the nokia cable, so i wasnt sure if the two issues are related.
H22sparkle: Learning to tune comes with experience, you have to know and understand everything i've ever written or posted on tuning. And then after that you'd have to go to pgmfi.org to learn the rest of it. I can't just tutor someone so much so that they become a tuner. Theres simply too much to learn
Lowcord:
its probably the nokia cable thats your problem.Knowledge is power...in EVERY sense of the word
well when i first installed my 3 bar with my uber, i checked the 3 bar option in uber and the vac values went all fucked up. Like i would have -24.5, -22.5, -19.5, 31.5 31.5 and so on, just in some random cells tho...it was kinda weird, mike is your vac values fucked up at all?
justinMy baby laying down some power...
http://www.youtube.com/watch?v=kd_Q8HSIyqA
ok mrx is a newb!!!
3 bar map will work with 2.5 bar map option in uber. you can then change the maps to what you want. ex= 1, 3, 6, 9, 12, 15, etc. if you go higher than 16, you're the proud owner of a cracked block and a $500.00 car. haha jk.
back to me reading between the lines. email me or antoine your crome map so we can look at it as ours die immediately. crome is much more customizable. help us help you.
antoine i'll forward it to you if he emails it and vise versa.I hate thieves!
