Has anyone had any experience w/ obx turbo manifolds? The ramhorn design in particular?
obx manifold
that was what i was thinkin 275$ for a ramhorn mani?!?!?! That's not a bad price at all might have to go w/ that one!Originally posted by d112crzytheyre good. obx has some strong products, i know of several people who have been using them for a while without any problems.
Just b/c U post more doesn't mean U know more!
My friend has been using it on his eclipse for almost 2 years now. No leaks or anything. A word of advice, ditch the crappy gaskets for some OEM's. On the WG flange you can use the crap, but i would use some high temp sealant. Otherwise it can leak after a while. The material that the gaskets are made of do deform over time.
Not sure what I'm explaining.
http://cgi.ebay.com/OBX-Turbo-Manifo...QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/OBX-S...spagenameZWDVW
the first one is made of a cheaper, less durable metal that doesn't resist heat as well as the second one. The second one is made of aircraft steel that's used on aircrafts exhausts. the second one is gonna hold up to any temps you throw at it. It's also $105 more dollarsShift_BOOST
BOOM!
i think it would be hard to tell the diffrence between the two especially since the first doesn't have that good of a description. If you look at the other ram horn mani for other cars they're a lot cheaper. I think the price diff has to do w/ the fact they prob don't sell very many f series manis. Just a thought though. 92ex do u know of any websites that actually show the comparison between the two?
On top of that is doesn't actually say it's a ram horn design! The pic isn't working and it doesn't say at all what type it is!?
its kinda ramhorn. not completely, but for about 100 bucks more than a log, I'm getting the obx. The difference is in the metal, read the descriptions and notice 2 different gauges of steel are used. My dad was an aircraft engineer so thats how I figured out the steels differences. The fact that one is for the h23 and one is for the f22 is irrelevant, there interchangeable anyways. I don't know why the pic isn't working, but it looks almost identical to the cheapers one.Shift_BOOST
BOOM!
this is what i found on the diff between the two
321
Better resistance to temperatures of around 600-900°C is needed…321 has higher hot strength.
304
Typical applications include:
Aircraft exhaust manifolds
Expansion joints
Bellows
Furnace parts
Heating element tubing
Lmao, I bought mine without paying much attention. Good thing the only one that was available was the expensive one!Originally posted by 92exNot sure what I'm explaining.
