hey guys an girls.. I wanna install a high compression pistons without the boring an things of that nature. i know the f22's come with a 8:8:1. wanted to see what companies out there offer a highier ratio, like a 9:6 or 10:5. so if anybody know of anything just hit me up...
pistons
Wiseco have off-shelf higher CR pistons with stock 85mm bore. I know www.raceeng.com is one source, do research for others to compare pricing.
I was about to post a thread regarding a 85mm piston but with higher compression.
a .040 oversize B20 piston is 85mm and i know RS machine offers a high compression cast piston and it will cost less than 200 bucks.
the only complication is that the wrist pin is different. they run a .827 as opposed to the .866 like f22's.
Now if you can hone the piston bore out .040, will it lose its integrity? I really want to try this because i have a f22 with only 30k miles and the bores are hardly even worn (which reminds me, i have it sitting outside uncovered and the walls are starting to rust)
hum Ive been thinking...Originally posted by wed3k View PostI was about to post a thread regarding a 85mm piston but with higher compression.
stock press fit rods, and a b20 pistion with the hole board out to the right size. Sounds like an economical solution to making moderate amounts of horsepower reliably... I have boost in mind for this combo. I am going to do some sort of build in the next 6 months, and I just don't think Ill have the cash to get f22a forged pistons and rods. The cheapest pistons Ive found are around $450 and you can get some 4340 rods for around 250 on ebay or grab some from bisi for 320.
*Edit* A friend of mine got some of these pistons cheep, but it looks like they are just as expensive as anything else normaly.Last edited by dbsharp; 08-26-2009, 02:08 AM.spin city
meh, ill ask about it tomorrow. you'd have to get custom bushings made because i know that all the bushings ive done are usually only .010 over size. so id have to get .025 oversize.Originally posted by d112crzy View PostYou can still rebush a stock, press fit rod.
however using the smaller wrist pin will lighten up the assembly which is always a plus.
I originally wanted to use a K20 piston but i didnt feel like going 86mm.
here's the D/l.
you can rebush them but it will have to be a custom bushing for sure. if you can find a bushing insert that is off the bat .040 or over thick but will fit in a .866 hole then it will be perfect that way you wont have to bore the rod to fit a bushing.
If you bore the hole, you weaken the material.
Honing the piston is still doable but taking .040 out of the piston will take a LONG time. It takes me half a day just to do a full set of rods on a v8. you also have to worry about the length of the wrist pin, i dont know if the castings in the pistons differ for length.
another thing is that the dealer on honda market for RS machine flaked. so trying to get a cast B20b high compression piston that is .040 (85mm) may be close to impossible. the only other thing is to tap into other people's old stock of RS pistons.
I have a set of forged 85mm b16 pistons that would yield between 9-10:1 compression depending on which head I use and the actual lenght of the rod I use.
I am going to attempt to use these in my super low budget turbo build. my question is: do the stock rods have bushings in them or is the .866 hole just machined into the steel?
Is there any reason that I could not use the floating wrist pin press fit into the rod?
I have sent bisi and cat emails about getting a f22a rod made with the smaller 21mm ID bushing. maybe I can get a forged rod made to fit. The other option is for me to buy a 4340 rod and press the bushing out, draw a design up for a new bushing and try to get it machined.Last edited by dbsharp; 09-02-2009, 12:09 PM.spin city
well, the wrist pin woul dhave to be a .866 and you would just hone the rod out a couple tenths or thou (since they are a press fit)Originally posted by dbsharp View PostI have a set of forged 85mm b16 pistons that would yield between 9-10:1 compression depending on which head I use and the actual lenght of the rod I use.
stock rods have no bushings.
a h22a4 uses a bushing, im wondering what sizes they can offer.
I am thinking that a stock rod with a a custom steel bushing that has a FN2 fit (about .001" interference) between the rod and bushing, and wrist pin and bushing would allow me to use these pistons with stock rods. I wouldn't use the c clips that came with the piston, I would just press the wrist pins in there.
Opinions?spin city
