This isn't as bad as the guy who wanted to hook up a VTEC controller to his F22A so he could add VTEC to it.
Super V-tec
This topic is closed.
Toda camsOriginally posted by GhostAccord View PostSearch for VTEC Killer cams. There are a few vids out there and they idle very rough. Saying it lopes is an understatement
The toda cams lope, yes.
I was wondering if a stock v-tec cam with stock duration and lift would lope. The Toda ones are quite aggressive compared to stock (I assume)
Thats why I was wondering if the stock ones would lope.
Actually...Originally posted by rexload View PostI would love to hear it idle in vtec too lol
Note to noobs: you CANNOT connect VTEC to any switches.. ONLY your ECU!
You can hook v-tec up to anything that will throw a 5 volt signal to the solenoid to open.
So you could hook it up to anything listed, even the brake pedal if you use the break switch...
Hmmm no you can't. The ECU has to switch to the hi-cam fuel and timing table when vtec engages... I'm sure you already know thatOriginally posted by Ghetto_CB7 View PostActually...
but some noobs think you can just hook it up to any switch... that is why I said that
Technically you could actuate the VTEC solenoid with any 5v switch. But like you said, the ECU will not make the proper fuel or timing adjustments. Therefore, installing a manual VTEC switch and engaging it at any time other than set from the factory is pointless. It may even end up harming your engine if run for extended periods of time with improper fuel and ignition.
right...it's not JUST the actuator that is affected...Originally posted by rexload View PostHmmm no you can't. The ECU has to switch to the hi-cam fuel and timing table when vtec engages... I'm sure you already know that
but some noobs think you can just hook it up to any switch... that is why I said that__
__
I'm not sure about this but might mention it. Long time ago this came up about having VTEC engaged all the time and main problem was oil pressure. Mainly due because the sys has to have enough pressure to operate properly, and usually in low rpms you don't have that pressure. Weather or not this is true I have no idea not sure how creaditable the source was.
"The Turtle"
DD/Trail Rig/Mud Bug
Yes saying it lopes is a big understatement. Just looked a few up and wow, sounds good, kinda reminds me of my truck with the cam it has.Originally posted by GhostAccord View PostSearch for VTEC Killer cams. There are a few vids out there and they idle very rough. Saying it lopes is an understatement
"The Turtle"
I really love all of this.
I always wondered about all the different ways to make VTEC engage when you want it... instead of having to wait.
Slamage is worth the Damage
Originally posted by crazymikey"Yes, we did officer. By the way, your eyes look a little glazed, did you just come from the donut shop?"
lmao! well at least ur gonna be just walkin on dodge stealths... literally.Originally posted by PR CB7 View Post
They rise their wooden pints and they yoik and sing
And they fight and dance 'till the morning
Dont forget my MRT for my 1992 Honda Accord LX
Originally posted by deevergoteEverything in Japan is made with carbon fiber and used panties.
