What does AEM EMS have that chipped P06 doesnt.......
f22 to h22 IM adapter with Skunk2 IM installed see pics, dyno to come
Originally posted by PR CB7 View PostLol@ glory
From my experience with h22's the skunk 2 manifold robs the motor from the little torque it has
So I personally think with that manifold and that thick spacer will kill the best part of that motor, torque...
Btw I've had 2 fire burnt ems fixed from aem
Bro just switch up to SDS-EFI. Fug AEM, the only thing I like that they make is the dry flow air filters, worlds better than K&N. Get a coilpack off a malibu from a junk yard, and pow. coils instead of a dizzy.
Originally posted by MortsAccord View PostHey now, Ectune is nice stuff. but lots of people hate on it because to DIY you almost always have to use an ostrich 24/7. I hates on some crome though, not that it doesnt work but its not as good as some people think it is.
is there a diy on those coil backs and what ems do you have to run
thats why i've got hondata, $600 and none of the aem headache and i can still use c.o.p. he really should do a comparison of the h23 IM and the Skunk2. also for the comment from julio the f22 has a 1.3" longer intake port and with the spacer and gaskets another 1" atleast. the new skunk2 manifold has 12" runners so that puts the total runner length at about 16.6" with 52mm which puts peak tq at the same exact place as the h23 intake manifold but it being a straight shot, not a 90deg turn you can get more air in at all rpms. the new design is canted instead of being level with the opening so air doesn't hit the roof of the port before entering. im fairly certain it should build more power all around but how much is the question. im wondering if it is worth the $$$ for the swap. peak numbers are not what concerns me is the overall picture.
Originally posted by jdm92_accorn View PostHey man, did you ever get your ecu problem squared away?
I got new ECU a while back. But I've been really busy with work and the FD when possible. But the FD is being put on hold again.
The manifold is currently off the car because the car overheated and melted the gasket earlier this year. But the main reason its not done, is I had to remove things to pass smog this year. But that's over with now. So I'm getting back on the CB. I wanted to hold off adding anything else for the after dyno. But that's not going to happen now. I have parts piling up on my shelves in the garage waiting to be installed.
Transmission will be the first major upgrade. Then the built head and manifold go next.
Originally posted by Dy2*STR33T-KING View PostI would like to know as well. I installed my h23 IM today and didn't swap runners with the a6 because I don't have my extended bolts to double stack (on the way) and I lost my low/mid but have more top end. Ugh. Updates here NEEDED!
You could also try sepulveda87 he doesn't have a MRT but he has done the skunk2 IM swap.
