Hey I have a '91 accord with an H22. The top end is built and now I am moving on to the bottom. I found some pistons made my Mahle? They bump the compression up to 11.5:1 And I would get the Eagle extreme rods to go with them. So I guess I just have a few questions. I don't know a lot about cars, but I know just enough to get me introuble. Is that compression ok? If not, what would a good one be? I want to be quick, but I want to still be reliable, and safe. Next, I heard sleeving the H22 is a pain? Lol, is it? Someone I was talking to told me that I should upgrade my crankshaft to be safe, should I? I think that's it. Thank you for dealing with my questions, even though they may be stupid. I just want to be careful. Thanks guys!
Bottom end build.
Do not upgrade your crankshaft,it pointless.There are turbo guys runnin 400 plus hp on them.There is no reason for you to sleeve the block, as the pistons you are talkin about are the only ones compatible with stock sleeves.I'm pretty sure 12.5 compression is daily drivable, so i think you should be ok with 11:1.I also doubt there is alot of tuning needed since stock h22 comp. is 10.6.I hope this answers your questions and do your homework
ILBBPeople I have dealt with in this board- Smseagren83,d112crzy, Idrivealude, aznpnoyracer, wed3k, dinertime, HF22T, MRX, Dc2lewd, yeamans17, bruno8747, tn_accords, king james, starchland, yardiexd40
Mk3 Supra Member #2
Originally posted by DarkShadow707The world needs to be reset.
I am planning to stay N/A, probably should have stated that. I am also planning to get Hondata or Neptun. I am just looking for some suggestions or what other people are doing. I have all skunk2 springs/retainers, skunk2 valves, skunk2 camgears, skunk2 stage 3 camshafts, skunk2 throttle body, aem fuel rail and pressure regulator, and arp headstuds. Thanks guys. Any suggestions would help!
really u should just do head work and higher compression then tune, i dont see anything wrong with the bottom end as of right now, isn`t it new?? anyways.. hey, make sure u dont rev past like 8.5k on that, cause it can do harm, like i bet with those cams u make most power around 8.2k ish anyways, others input would be nice but ya, be safe cause it wont be fast for long if u beat it, it is one clean car and now u own a sick car soo good luck and i hope everything goes well...
Shawnee, would you like me to put my car on a dyno while it doesn't run and get it tuned? I am waiting until the wiring problem is fixed until I go buy a hondata and get it tuned. You know what ECU and chip I am running?What are you talking about? If you knew then you would know that I have a bone stock p13 ECU. I'm not running any chip! I will see you tonight!
