Delta 272 install Problems help if experienced!
    I've spent the past 9 hours trying to install my 272 regrind I am having trouble getting the rocker arms to line up to the bolt holes. I haven't had any other trouble but this is really starting to get me frustrated. If any of you guys who have installed this and know what I'm talking about, please reply with some suggestions or trick to get all of them lined up. Thanks for the replies in advance!
    Keith
    Former Ride:
    93 Accord Coupe
    Jdm H22 w/ LSD
    Type S pistons and cams
    New Ride:
    Bone stock 99 2.3CL
    Black on Black Leather
    5spd
    "Experience: that most brutal of teachers. But you learn, my God do you learn."
    C. S. Lewis
    this really sucks. I could only work on it for like 3 hours, then i had to go to work. 13 hours later still no progress. OF course we aren't working on it anymore...this is just ridiculous. My GSR was way easier and it has two cams....and 8 more rocker arms.
    H.S.A.E.
    90 CRX Si - gutted, caged, Bisi F2d kit, close ratio LSD trans, F22A6 - under construction
    99 civic LX - y8 head and trans, lowered, blowing cold AC, and getting 35mpg.
      Did u guys accidentally have the rocker arm assembly spread apart on you because you removed the screws??
      If the holes don't like up, I bet the rocker arm assembly was either not put back together correctly in order or is not compressed completely how it should be.
        Should just flow right in, and be problemfree....
        Um, re-walkthrough your dissasembly process
          well, we got everything back in but my timing belt tensioner bolt was too tight and we accidently rounded it off. I had it towed to a shop to have them just take that bolt out and slip my timing belt over my cam gear. I'm waiting on their call to go pick it up. I have lots of pictures that I'll do a write up on.
          Former Ride:
          93 Accord Coupe
          Jdm H22 w/ LSD
          New Ride:
          Bone stock 99 2.3CL
          5spd
          C. S. Lewis
            what was the cause of your issue as to why the rocker arm assy did not align?
              Cause he removed the bolts, no? I did the same thing, I had to buy another rocker assembly.
              My official vouch thread!
              Updated!!! --> My official turbo progress thread
                why couldn't you just put it back together??
                  Well I could and I did try, but I couldn't get it right, so i'm like screw it...I needed another head anyway...
                    I did take the bolts out and it fell apart. I thought it was straight but I just couldn't get all the holes lined up with the head's holes.
                    I talked to the guy at the shop that is fixing it and he said it's going to be around $425 for everything. That's just for getting that stupid tensioner bolt off and setting the valve lash (which I was going to do anyways). For that amount of money, I could have paid someone to put the cam in for me. This whole thing has pissed me off extremely and I should've just had someone do it for me.
                    The only thing I've gained from doing it myself is the experience....which may be worth it in the long run.
                    Former Ride:
                    93 Accord Coupe
                    Jdm H22 w/ LSD
                    New Ride:
                    Bone stock 99 2.3CL
                    5spd
                    C. S. Lewis
                      lol all that happened is when u take the rockers of the stock cam it moved just a little bit this could have been easily fixed used a screw driver for alignning the holes and rubber mallet 2 make it move and bottom line if u don't know what u are doing get somebody else 2 do it for u it's a pain sometimes with the rockers and i myself had 2 take the well really didn't have 2 but i did and put it back together in 30mins at the most please 2 save u money in the long run don't attempt 2 do something if u are not mechanically inclined 2 do so not trying 2 be harsh but it's the truth
                      H23vtec
                      Kee Built/Tuned
                      87x95 11.7 compression, custom h22 intake, minor head port polished, 70mm tb, 3inch cold air/3inch vstack, stock cams,ebay header with 3inch collector,3inch exhaust.
                      9.0's at 81mph in the 1/8th mile ohh how i miss my baby.
                        Only if you carried it through to the end....with the good and the bad. Otherwise you still lack what "they" did for you.
                          well, i got my car back today and It runs great. I found out that They spent extra labor hours adjusting my crank timing. It was off and I don't know how to do that so I felt better spending the money that i did.
                          Former Ride:
                          93 Accord Coupe
                          Jdm H22 w/ LSD
                          New Ride:
                          Bone stock 99 2.3CL
                          5spd
                          C. S. Lewis
                            actually if you read the post you'll see that we did get the rocker arm assembly back in, it was just a pain in the ass, and harder for one person to do. Once both of us were there to work on it it took a matter of minutes. Just took some tapping with a mallet. I think the trick was just leaving the bolts in, and tightening it in sequence, all of the ones that weren't lining up did after tightening the others.
                            lol...I think he lost the motivation to do a write-up tho! At least it's running strong.
                            H.S.A.E.
                              good to hear it's running strong.
