i bought the msd sci box. i dont understand the two wires that shouldnt be used at the same time. the white wire which is described as "to points or amplifier output (connects to yellow wire of timing accessories)" the other is a plug that has a green and violet wire and is described as "to magnetic pickup in distirbutor or cranktrigger." i would like to hook it up but im stuck as to which one im suppose to use and how to find it in my car. i have a 92 accord ex with the f22a6. thanks in advance
MSD box issue
The white wire is the points wire, correct... and this should be used to trigger the MSD box. Connect it to the original wire that used to go to the negative terminal of the stock ignition coil's primary. You will know if you hooked up the rest of the box properly if you get a spark when you touch the white wire to ground.
If you are using that, do NOT use the green/purple wires. This is a different way to trigger the MSD ignition, and would be connected to a magnetic pickup, as the manual states.Last edited by Dirty Harry; 12-17-2005, 11:09 PM.
ok theres 3 wires going into the external coil plug. yellow, black n white, black n yellow. i have a blaster ss coil from msd. orange and black are hooked up to it. thick red and thick black go to the battery. white and red? do they get hooked up to the 3 mentioned above? im lost help me out
try here: http://www.cb7tuner.com/vbb/showthre...805#post521805 mine's a 6A but you get the idea....
