i'll be adding my msd 6a next week...i'll post pics.
ENG: Internal to external coil
When I did this to my 95 Accord EX, I just took a peice of sheet metal about 12" or so long and bent 1/3 of it at a 90 degree. Then I mounted the external coil to that 4" section I bent up. I then slid the rest of the metal under the battery and tightened the battery down. The battery held the sheet metal and coil in place and I didn't have to drill into any part of the car. It looked clean and was easily reversable if needed.Originally posted by chilefinally did mine...the only bitch was mounting the coil somewhere.
Just a thought for anyone having trouble figuring where to mount the coil.
good idea...i'm gonna get a blaster ss after i do my head swap...i installed my 6A this morning...took about 30 min...taking out the ballast resistor makes the wiring look a little cleaner (at least in my case)...Originally posted by TouringAccordWhen I did this to my 95 Accord EX, I just took a peice of sheet metal about 12" or so long and bent 1/3 of it at a 90 degree. Then I mounted the external coil to that 4" section I bent up. I then slid the rest of the metal under the battery and tightened the battery down. The battery held the sheet metal and coil in place and I didn't have to drill into any part of the car. It looked clean and was easily reversable if needed.
you don't have to buy a their modded cap you can
just convert yours for like $10
How 2 External Coil ??????Last edited by smokeeey420; 08-19-2006, 08:15 PM.
Originally posted by smokeeey420you don't have to buy a their modded cap you can
just convert yours for like $10That gets my vote. OEM caps such as the '94 are fine, and no drilling/epoxying whatever required. Besides, with modifying a 90/91 cap you're just going to have to do it again later.Originally posted by ACCORDingI just used a cap from a 94 accord. It fits perfictly and is external coil>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
just a thought. Oem caps are fine but the connection is not brass or gold like the msd cap. Better connection for better spark energy. Plus a new oem cap cost almost as much as the msd does with a rotor and coil wire.
Putting in my setup tommorow with a new dizzy, venom 400, nology wires. I post if theres anything worth noting.No longer working on the cb. To much time and money has been put into it. Check my for sale thread where the whole car will be parted out.
From me, the thread starter. I have one because I'm using an MSD ignition now.
Give me your address and if you can paypal me $10 I can send it to you asap. Depends how fast you need it, if you can't find it locally. Shipping will be more if you want it really ASAP. I see you're in Canada.
PM me or see me on AIM tomorrow afternoon.Metal Metal and more Metal!!!
How much does your wheel/tire combo weigh? Post here!
-=Suicide Crew Member #1 (only member so far)=-
MY RIDE
"I was hoping the Wolverine would finger one of those Japanese girls and then extend a claw into her b hole just for fun, BUT that never happened and I was extremely unsatisfied with the movie because of it." -Macaqueistrong
i have read on different threads that there is no need for the resistor. In this thread it was stated that the blaster 2 has one built in, but the blaster ss requires one (which is what msd instructs) So, is there anyone that has done a ss without a resistor or ignition box and can give a straight forward answer hopefully learned from experience? I really need some clarification on this bc i rather not waste my time with the resistor if is not needed.
good diy by the way, thanks for doing it.
Do you have any more pictures of when you finished everything up? My distributor went out on me and i bought an h23 distributor thats already external coil i just dont know how to hook it up. heres my problem
http://www.cb7tuner.com/vbb/showthread.php?t=75060
If anyone know's the best way to fix it let me know. thanks.
