272 delta cams.......
    Stock valvetrain? Or aftermarket?
    Turbo H23a3 build has begun
    01-01-2019
      stock.
        Check this out, found it online.
        OIL IS KILLING OUR CARS!!!!!
        By: Keith Ansell, Foreign Parts Positively, Inc.
        About a year ago I read about the reduction of zinc dialkyl dithiophosphate (ZDDP) in the oils supplied with API approval that could affect sliding and high pressure (EP) friction in our cars. The reduction of these chemicals in supplied oils was based on the fact that phosphates reduce the effectiveness and eventually damage catalytic converters and introduce minute amounts of pollutants into our atmosphere.
        A couple of months ago I had a member of the Columbia Gorge MG Club bring a totally failed camshaft and lifters back to me that had only 900 miles on them!! I immediately contacted the camshaft re-grinder (Delta Cam) and asked how this could happen. They were well aware of this problem as they were starting to have many failures of this type.
        In the past, the lack of a molybdenum disulfide camshaft assembly lubricant, at assembly, was about the only thing that could create this type of problem. My customer has assembled many engines and had lubricated the camshaft properly. Then the bad news came out: It’s today’s “modern” API (American Petroleum Industry) approved oils that are killing our engines: Meaning all flat tappet (cam follower) equipped engines, as used in all BMC products, all British Leyland products, most pushrod engines prior to 1980, early Volvos, American high-performance engines and many others.
        Next call: To a major camshaft supplier, both stock and performance (Crane). They now have an additive for whatever oil you are using during break-in so that the camshaft and lifters won’t fail in an unreasonably short period of time. They also suggest using a diesel rated oil on flat tappet engines.
        Next call: To a racing oil manufacturer that we use for the race cars (Red Line Oil). Their response: “We are well aware of the problem and we still use the correct amounts of those additives in our products”. They continued to tell me they are not producing API approved oils so they don’t have to test and comply. Their oils were NOT the “new, improved and approved” ones that destroy flat tappet engines! “We just build the best lubricants possible”. Sounds stupid, doesn’t it, New-Approved but inferior products, but it seems to be true for our cars.
        To top this off: Our representative from a major supplier of performance and street engine parts (EPWI) stopped by to “warn us” of the problem of the NEW oils on flat tappet engines. This was a call that the representative was making only because of this problem to warn their engine builders! “The reduction of the zinc, manganese and phosphates are causing very early destruction of cams and followers”. They are recommending that, for now at least, there must be a proper oil additive put in the first oil used on new engines, beyond the liberal use of molydisulfide assembly lube. They have been told that the first oil needs the additive but remain skeptical that the first oil is all that is necessary. Their suggestion: Use diesel rated oils such as Delo or Rotella that are usually available at auto stores and gas stations.
        This problem is BIG! American Engine Rebuilder's Association (AERA) Bulletin #TB2333 directly addresses this problem. I had a short discussion with their engineer and he agreed with all that I had been finding.
        Next phone call was to a retired engineer from Clevite, a major bearing and component manufacturer. First surprise was that he restored older British Motor bikes. The second surprise was that he was “VERY” aware of this problem because many of the old bikes had rectangular tappets that couldn’t rotate and are having a very large problem with the new oils. He has written an article for the British Bike community that verify all the “bad news” we have been finding.
        Comp Cams put out “#225 Tech Bulletin: Flat Tappet Camshafts”. They have both an assembly lube and an oil additive. The telling sentence in the bulletin was “While this additive was originally developed specifically for break-in protection, subsequent testing has proven the durability benefits of its long term use. This special blend of additives promotes proper break-in and protects against premature cam and lifter failure by replacing some of the beneficial ingredients that the oil companies have been required to remove from the “off-the–shelf oil”.
        Next question: Now what do we do?
        From the camshaft re-grinders (DeltaCam) “Use oils rated for diesel use”, Delo (Standard Oil product) was named. About the same price as other quality petroleum based oils. They have the ZDDP we need in weights we are familiar with.
        From one camshaft manufacturer (Crane): “use our additive” for the first 500 miles.
        From General Motors (Chevrolet): add EOS, their oil fortifier, to your oil, it’s only an 8-ounce can (This problem seems to be something GM has known about for some time!). The additive says for break-in only, some dealers add it to every oil change.
        From Redline Oil: Use our street formulated synthetics. They have what we need! Early in 2007 they will be supplying a “break-in oil” specifically for our cars.
        From Castrol: We are beginning to see a pattern emerging on older cars. It may be advantageous to use a non-approved lubricant, such as oils that are Diesel rated, 4 Cycle Motorcycle oils and other specified diesel oils. They will be supplying “new oils” specifically for our cars in early 2007.
        For you science buffs: ZDDP is a single polar molecule that is attracted to Iron based metals. The one polar end tends to “Stand” the molecule up on the metal surface that it is bonded to by heat and friction. This forms a sacrificial layer to protect the base metals of the cam and tappet from contacting each other. Only at very high pressures on a flat tappet cam is this necessary because the oil is squeezed/wiped from the surface. This high pressure is also present on the gudgeon pin (wrist pin) in diesel engines, therefore the need for ZDDP in all diesel engines.
        Second part of the equation is Molybdenum disulfide (Moly). The moly bonds to the zinc adding an additional, very slippery, sacrificial layer to the metal. I found out that too much of the moly will create problems; lack of this material reduces the effectiveness of the ZDDP. The percentage, by weight is from .01 to .02%, not much, but necessary according to the chemists.
        Now there is no denying that there is a problem, lack of ZDDP (Zinc Dialkyl DithioPhosphate) in modern oils kills at least our cams and tappets. There seems to be no known alternative.
        The “Energy Conservation“ trend was first led by automakers to increase mileage numbers and secondly because the ZDDP and other chemicals degrade the catalytic converter after extended miles, increasing pollution. Most of us don’t have catalytic converters and the mileage gains are not that significant.
        On “modern” production cars, stay with the manufacturers’ suggestions. For any car produced before about 1990 the owner needs to be aware that the factory suggested lubricant may have changed and may not be applicable. Flat tappet, stock, performance or modified may be affected. MGBs from 1975 to 1980 must choose to sacrifice the cam or the catalytic converter as an example of how difficult the decisions are becoming!
        Yes, there is more! Castrol does understand our dilemma and is actively looking into what it can do to support our cars. We can soon expect to see products from them with specific application to classic cars. Red Line will be offering a “break-in” oil soon after the first of the year. Shell’s Rotella will be good until about June or July of 2007 with possibly nothing after that date. Delo (Chevron) will also be questionable after the new “CJ-4” standards come in the middle of 2007.
        Now the important information: Oils that may be correct for our cars today: (As reported by manufacturers by 12-31-06, NOTE: many have changed their recommendations over the last three months!
        Castrol: Syntec 5W-40, Syntec 20W-50, Grand Prix 4-Stroke Motorcycle oil in 10W-40 and 20W-50, TWS Motorsport 10W-60*, BMW Long Life 5W-30 ( full synthetic, available only at BMW dealerships)
        Red Line: 10W-30, 10W-40 (Synthetic oils)
        Valvoline: VR-1 20W-50 (Conventional oil)
        Amsoil: 20W-50(TRO), 10W-40(AMO), 15W-40(AME) & 20W-50(ARO)
        Mobil: Mobil 1 5W-30 and 20W-50 (Synthetic)
        Chevron: Delo 400
        Shell: Rotella
        What we are doing at Foreign Parts Positively has been difficult to determine but with few options left, the following is what we are forced to do. Some of our choices have been based on the manufacturer’s willingness to help and specific reports. This list will change in the next months with Castrol and Red Line adding products just for our cars.
        We have received some very interesting material from “Mr Moly” that may be putting molybdenum disulfide (MoS) into this discussion. It seems that ZDDP plus MoS is the best from the oil companies’ opinion but MoS by itself may be beneficial. Some racers swear by it. The literature seems to support “Mr. Moly’s” position.
        Keith M. Ansell
        www.ForeignPartsPositively.com
        Kma4285@msn.com
        360-882-3596
        Also, did you use the cams from that motor or another set of cams that you had re-ground and then installed? I did it that way and had to have the cam caps and head line honed because the cams I used had a larger diameter bearing surface. You might want to plastiguage the cams and check the tolerance, they might be real loose in the cam caps.
        L8r
        01-01-2019
          L8r
          I'm thinking this might be it.
          The cams he used are from my f22b dohc, now in his f22b dohc.
            Originally posted by d112crzy
            Right now, I think its at .14 and .18? I don't remember exactly, but we did on the loose end and it was louder than the tighter.
            We set them at .14 and .20
            3 CB's gone....
            1 WK Overland....
            Still miss the CB though......maybe one day.
              so whats the best setting for the 272 cams on the h23 eng? this threads got like 5 different set of numbers.
                To add Delta 272 cam input for a F22ax SOHC motor, I set mine to .009" INT and .011" EXT. That is slightly tighter than stock valve lash specs. The oil you use does make a difference. I have good success with Mobil1 5W-30, but am currently on a Royal Purple synthetic 5W-30 oil change because I was curious. I am going back to Mobil1, simply because I did not notice enough of a difference to justify it being harder to get in my local area and more expensive for what is my daily driver (red Accord). Both oils however, keep the internals of my motor clean, as everytime I've had to get under valve cover for valve lash adjustment, super clean.
                Anyhow, the key to any performance cam on these F22ax SOHC motors I've noticed, is you have to increase the your internval for valve lash adjustment. Meaning instead of 15,000 miles recommended for stock by manual, I do it every 12,000 miles. I've noticed the more you rev the motor, the tighter the clearances get over time, which means more valve train wear. On my white Accord, I have yet to determine the rate, it may need it sooner, I'll check it at 5K and then 10K and base it off that when time comes.
                  this isn't related but I was told by delta that the h23 cams with delta 272 grind has 222 duration at .410 lift. Why is this so different than the 201 duration Ive seen posted for the f22a cams?
                  spin city
                    dameee. i got the cam lubed up and tq down.
                    i set the IN to .15 and the EX to .20.
                    now the cam acks like it doesn't want to turn. and the lobes look like there touching the lash bolt
                      Are you trying to turn it by turning the cam gears?
                      It's going to be fairly hard to do that, especially if you're hitting the pistons.
                        no. the crank pulley bolt.
                          You sure you lined up everything correctly then?
                            x2 you need to double check this and make sure it is correct, unless you are looking for an excuse to get some headwork done.
                            spin city
                              i'm farely sure i've got everything to TDC. but the the cam gears i'm using(drakstar racing b18 cam gears), seem to look a half a tooth off.
                              i'm also using a GSR timing belt.
                                just call delta and they said IN .008........EX .010
                                some else please call to see if that's right
