272 delta cams.......
    makes sense. Wikked and the OP used .006/.008.
    The ones I and 91Accord-Lx did were 262's.
      Keep in mind that Delta tells you to do cams tighter than stock clearances to give more slightly more valve lift, making their numbers look better than they are. However I look at it from standpoint of that being more valvetrain wear, so I stick with stock-like specs or more exact, what Bisimoto recommends on his cams .009 INT/.011" EXH. After all, we're dealing with the same core cam here, it's a regrind.
        all better went with IN.20 EX.25. everything is turning.
        now i got to wait two freaking weeks for the tranny
          for the h23 you need .003"-.004" intake and .006"-.007" exhaust. thats where my 272's are set. today I noticed that delta's rocker arm ratio specs were 1.65, cower says that it 1.85, and I think ive seen that it is 1.85 somewhere else, so That would mean that the h23 272 cam has .459" lift at .000" lash. They qutoed me something like a 410 lift on the phone. also today i measured the stock f22b dohc cam today and it has .416" lift at .000" lash.
          spin city
            i called delta and was told IN.008 EX.010
              the specks i posted are straight from Honda's prelude manual
              spin city
                are you talking about stock cam spec. or the specs's for a delta 272 cam?
