Is there a way
    Is there a way
    is there a way to engage vtec with out a ecu for it, like wire a switch up or something, cause i just swapped in a f22b1, dont even care if im in vtec all the time cause it starts to pop after 4700k, i know get the P0A ecu but some thing just for now
    fuck the bitches that stole my car jan/1/2006@7am from montesano wa updated: The Warrens from Malone Wa were found guilty for possesion of stolen property in the 1st*and were ordered to pay $2489.69 in restitution, only cause the shell was not found
    R.I.P.
    Vouches from: Snailin91, Caution, 2G6, Jdmf23accord, Boosted_StinkyNuts
    P28 would work for the f22b1 and if you want to tune it later on that would be the better ecu to use. But to engage vtec without an ECU on it your kinda fucked on that one.
      what is the p28 out of this is is the ecu i will need later when i boost
      R.I.P.
        Yea if you plan to boost i would use that ecu. 92-95 civic ex or si.
          you could actually do just what you want.
          some guy in town is running around like that. He can pretty much engage vtec whenever he wants to with a switch.
          fucking stupid imo. just hook it up to the ecu, its not hard at all.
            he wanted to have VTEC without the ecu enabling it. so how is that? lol!
            imo just slap on a vtec sticker and u will have vtec...thats what the kids do around my town. im thinking of doing it.
            F22a1-->F22A-->H22A-->auto-2-5spd-->K20 6spd-->F22C 6spd RWD-->4G63 6spd AWD-->K24 6spd????
            Sold to: blackice, Myothercar, Rennat, Ilikebigbutts, HA91, DA92CB7, accord91lx, Cb7GHOST, Gemini, whiteaccord92,Warudakumi, jhondayaaj
            Bought from: 93twodoorLX, Datmofo, g7kobayashi, accord_inspire, Accord SiR, Kurobei, UK-Accord, phreakish93, RENR, k-mart
              yea, he can make a switch that he enables himself.
              normally, the ecu reads off by rpms and speed and engages vtec. he can make a switch that he can turn on whenever he wants to.
              thats what i meant, that he CAN do what he wants to do by making a switch.
                with a ecu that doesnt even support vtec?? wtf u smokin man.
                  blah, i just re read the first post. I thought he said that he already had a vtak ecu.
                  my bad sean, please forgive me. i'll buy you some jdm goodness.
                    hahaha, a best buy discount will suffice....after u have been there a while. simple mistake! no worried. u just had me all confused to hell. i thought u hit the crack pipe up again.
                      Actually Jose is right, you can use an rpm activated switch to turn on vtec whether it be an msd switch/vafc/or a generic rpm switch...I won't go into more detail but in no way is that close to optimal especially if you plan to boost. Run a chipped p28, you are going to have to get a chipped ecu either way if you plan on getting tuned
                      Retired 1990 Accord LX Coupe
                      Project 240SX
                        i not wanting to hook it up permently like this. i plan on getting the proper ecu for it but someone told me you can hook it to the tps so when you mash the gas it will engage or a switch not even a rpm switch, if the tps thing is correct what wire turns hot a wot
                        R.I.P.
                          After reading this, I found an rpm activated switch at Summit Racing for ~$40. I'm hoping to use it to open my H22's IABs just before VTEC since my P28 doesn't support the function.
                          The switch runs off a tach signal and puts out a ground at any rpm from 2-10k. You could probably use that to cut VTEC on by the solenoid and the vtec oil sender somehow (???), and you'd have to move your rev limit somehow...
                          You'd have to know what kind of signal the ECU was sending and duplicate it.
                          It would be interesting to know, I was just thinking you could adjust the vtec cut on with this cheap switch instead of a VAFC .
                          PM me and get it done right!
                            Dosent the ECU change air/fuel curves during vtec, so if you just hook it up to a switch, will you be getting the full effect of vtec?
                            Will's Accord
                              my solenoid i have is a one wire off a auto so i have had it hooked through my shift light on my tach for a week now and it works rather well i can pretty much pick were i want vtec to engage by means of were the light comes on i just took a light cover for the light and painted it black so i wont get snitched on lol but jose is now converting my ecu as we speak and i will have it hooked up a
                              R.I.P.
