I was wondering if you advance the timing by 1-2 degree's will it make more power or just shift the powerband around?
advancing the timing
you shift the power band. And prob wont make much at all.
I wouldnt think it would. Your better off buying a delta regrind or something else if you want power.
Id buy a delta 272 over advancing my timing. Plus you get more gains. If you really want to see if it neets you power take it to a dyno and play with the timing. Prob aitn gonna be much change with the f22 motors.
Originally posted by pig penwell it would be adjusting the cam gear soooo...........?
ignition timing and cam timing are two completely different things.
ignition timing controls the time of ignition, aka spark. what does spark have to do with cams?
people always get these two confused.
timing controls when the spark is given off, and cam timing is when you retard or advance the cam to make the valves open earlier or later.
I have my timing advanced and I did feel a difference, even in the low end. Just as an experiement, I retarded the timing and it felt really weak in the low end. I was always under the impression that advancing would give you more high end and retarding would give you more low end, but that's not what I experienced when I retarded the timingI say advance it some.
Originally posted by Granite CB7I have my timing advanced and I did feel a difference, even in the low end. Just as an experiement, I retarded the timing and it felt really weak in the low end. I was always under the impression that advancing would give you more high end and retarding would give you more low end, but that's not what I experienced when I retarded the timingI say advance it some.
Cali.Dumps.Harder.
loosen the three 12mm bolts holding the distributor on and twist it toward the firewall a bit. you can do it when its cold. ive noticed it usually helps out a bit, makes a sluggish f22 feel a little "fresher"... as long as you dont advance it to the point where it starts pinging at all while driving, i dont see how it could harm anything
Originally posted by 92excam timing controls spark and ignition timing controls the cam...you noob lol
Anyway I'm guessing advancing the timing would have a noticable effect on fuel consumption. Anyone have any experience with this?
