OK, not sure if this is in the right forum but it does have something to do with performance. Tell me if this sounds right to you. Me and a friend raced each other last week. I have a f22b dohc with K&N filter on stock pipe and a tanabe cat back exhaust, thats it. We just did a manual swap to his DX with f22a1 and upgraded with intake, lightweight flywheel, and full exhaust from headers back. Now Im thinking I would leave him by far but that wasnt the case at all. I was only pulling away from him slowly. By 3rd gear I wasnt even a car length in front of him. Does that soundright to anyone or does it sound like my dohc isnt running 100%. Feels strong though, and I know the DX might be a little lighter but that was unexpected. I raced a 96 sohc vtec and had the same results and this thing had cam gears, full exhaust, intake, MSD. Is is the lightness of the DX or what??
F22b DOHC vs F22a1 SOHC
yea that doesnt sound right to me when i had my dohc f22b in my last cb i could pull away from my bro's 94 DX cd he has intake, header back exhaust and the f22b1 has a little more power then the f22a1 not much but a tad more and i seens to leave him fairly easliy
PSN ID's:Tidashoni
1992 Accord EX Coupe
My FS Thread
Not so DD 2013 Subaru Impreza WRX STI
Originally posted by deevergoteBoosting with a carb is like being a sniper with a bazooka... it works, it gets the job done, but it's not the most precise method.
hey.
cam gears and msd don't really create power as much as give it to you in a different area, unless highly modified.
and yes this whole scene does make since.
when i had my sohc f22 i also had dc headers greddy evo 2 exhaust light flywheel stage 3 clutch h23 intake, and cai.
i beat so many other accords it wasn't even funny..
the 95 civics with vtec i would pull a car length by the time we hit 80mph.
i think the weight issue has alot to do with it..
you might also save up for a header, it's amazing how much that helps the top end breathe"Self Renewed"
my friend has a DOHC f22b in his 91 ex and he beat a 92-93 lx sedan last night by a good amount. (this was after my friend stayed in 3rd gear while doing 40 and still catching up and passing the guy out). it's pretty much a stock motor with stock exhaust. all he has is an intake, header, 8lb flywheel, stage 1 clutch. i think the other guy had intake/exhaust and i know for a fact it was a manual.
a kid in my neigborhood has a bone stock, auto. 5th gen and he beats that by alot.
Originally posted by arthaccordwell a lighter fly wheel is going to make a big diffrence any way and if your f22b is pritty much sticki could see how he beat you or did you win i forgot already
PSN ID's:Tidashoni
My FS Thread
Originally posted by almostJDMyea itll make a big differance in how fast the enigne revs thats about it plus i think they have about the same mods so its a 160hp 156tq vs 125hp 137tq plus identical mods
These motors maintain good HP for a long time unless they're built up with sludge and carbon build up in the combustion chamber. Anyway, By the end of second gear I had him by a driver side door.or half a car. He denies and said it was a tie, i mean its close to a tie but not exactly. The only mods he has over me is headers and flywheel. I know I would smoke him on the highway but if this dohc cant smoke a dx with those mods then something muss be wrong. We'll run again tonight and I'll film it this time.
Originally posted by tn_accordsthe flywheel has alot to do with this.. rememeber that the engine can gain its rpms faster if there is less mass to turn.
but you will loose force.. meaning you will have to rev higher just to launch at the same speed rate you would with a stock flywheel.
in "motor work work shop book, Honda and Acura performance handbook".
Chad Anderson specifically says this.
"A lightened flywheel will significantly reduce your engines ability to accelerate.""Self Renewed"
the only thing i could say is give some runs in the 1/4 to prove that.. because it just don't seem right.. because that just don't seem right IMO. I don't really read books.. just go by how they perform on the streets or at the track..
Originally posted by KeelesKustomei am thinkin a lil credit is needed for the f22 sohc. all it needs is to breathe..**Blk Housed Slut Crew Member #1**
