Originally posted by CB7 Sleeper
View Post
Dry Shot VS. Wet Shot
Originally posted by rexload View Postwhy would you need to upgrade the fuel pump? a lot of people use the OEM honda pump even at around 300hp without any issues.
well just replace it with an OEM pump then. you'll be good with the stock one. i plan on spraying too. talk to RICHIE*GTR35 too. he's been on spray before he swapped. was on a 75 then moved to a 100 shot and did that for a year.
with a 50-65 shot you should be good with 1 step colder plugs and retard the timing by a degree or two.
Originally posted by DejectedAngel View PostWhat i was wondering if its better to get direct port injection?Originally posted by CB7 Sleeper View Postnot sure?
a single jet into the intake will do fine
With direct port, your chances of a backfire are almost as small as having a dry nitrous backfire. Its not necessary for direct port unless you're doing over 100 (that is IMO only; theres people spraying more on a single nozzle just fine).
