Rear suspension pops
    Ok so when ever I go a slope like into a gas station I have to go side ways, and I go into tripod mode, and when that 4th wheels spring recompresses it let's out a loud pop, any idea what could be causing this? Acctually now that I think of it it doest it when ever one of the rears extends then recompresses, but it doesn't happen if Jack it up then let it back down
    PSN ID's:Tidashoni
    1992 Accord EX Coupe
    My FS Thread
    Not so DD 2013 Subaru Impreza WRX STI
    Boosting with a carb is like being a sniper with a bazooka... it works, it gets the job done, but it's not the most precise method.
    Try tightening the bolts at the top of the strut tower. If that doesn't work... it could be blown.
      K I'll check em
      PSN ID's:Tidashoni
      My FS Thread
        The spring could be popping out of the perch and when you drop back down it pops into place.
        Its just me
          If tightening up top doesn't work, check all the bolts behind the wheel. Even the sway bar.
          Hopefully something is just loose.
            Bill now that you mention that I think that's what it might be but I'll check both things, and Josh I don't have a rear sway I've got an lx, but I will be getting rear discs so I will soon
            PSN ID's:Tidashoni
            My FS Thread
              what springs do you have?
              Its just me
                I have the same problem with my sedan.. it was like that with the teins, ksports, and the d2s. Its not my suspension obviously.. I too get the pop sound every so often on a slope or uneven pavement. I have no idea what it is. I have checked all the bolts and there tight.
                I had it with drums and disc brakes.. I think it could be the bushings going bad. I want to replace them with prothane ones but not anytime soon.
                  Possibly shock bushings....
                  Originally posted by lordoja
                    could it be the arm hitting something when you go back down?
                    Its just me
                      They are nex type ss it's a full suspension cool over kit I'll just up one side and if the spring separates I'll be guessing it's that, after I eat breakfast I'll go out and see
                      PSN ID's:Tidashoni
                      My FS Thread
                        I know for sure it's not the upper arm I've double checked that Its got a good inch of space and it's a wikked tuning camber kit
                        PSN ID's:Tidashoni
                        My FS Thread
                          cool. i was just trying to think of some things that might hit.
                          Its just me
                            It's the springs poping back into place I raised the car a tad, not enough to stop it because if I did that it would be about 2" higher then the front lol and I'd have a 2-3 finger gap which I don't like, and it only happens at this 1 gas station because the slope to get up to it is kinda steep
                            PSN ID's:Tidashoni
                            My FS Thread
