Noob question about skunk2 coil sleeves
    Okay so I feel like a total noob question but I just was putting my sleeves on a got them all adjusted to the right height but then i realized i think there might be a front and rear spring. here is a picture of what mine look like and I am wonder which one is the front and which is the rear. Feel like an idiot asking but the guy i bought them from didn't know either.
    Red Wagon DD - 1993 EX
    http://www.cb7tuner.com/vbb/showthread.php?t=172734
    Gray Wagon Project - 1992 LX
    http://www.cb7tuner.com/vbb/showthread.php?t=166337
    I know with my megans there were, rear had taller springs.
    wat?
      Are the numbers the same on all four of your springs?
        On mine the front sleeve was shorter than the rear.
        115mm front
        180mm rear
        My springs are # 0800-250-010S
          X2 With the Megan sleeves. they come alittle taller , but also come in a box labled [FRONT] , [BACK]
          Check the numbers like they suggested above the rears might have different Numbers.
          Good Luck
          Check Out My Work In Progess . . . . .
            okay so the numbers are the same and the sleeves are the same length. now if you look at the picture look at the right ans left two spring notice the bottoms are different, these are how mine look. think the left ones are the front and the right are the rears or vis vs a
